Hi All, I'm gradually trying to get my Embryon back to being more or less factory-correct and am seeing references that at least the 3 messenger balls in the center of the playfield should be larger than standard pinballs... As you may remember, there are a total of 5 messenger balls on the playfield (apart from the 2 balls actually played) and I can't find any documentation as to the correct size. Any thoughts would certainly be appreciated! Thank you, uraprat
