Hey guys. So My '72 Swinger has been acting up lately. What will happen is when you score any 100 point target, the relay will pull in but not let go. I looked at all the switches on it, they seem fine. No contacts touching that should be normally open type deal. The spring tension seems to be fine, I don't want to tighten the tension on it either. This happened a while ago and I discovered a set on contacts being a bit close. I adjusted them and she was swingin' once again. However this time I can see no switches that look problematic to me. Any thoughts?
