(Topic ID: 151529)
EM Tech Tip: Quick Gottlieb flasher bulb socket ID
By DirtFlipper
8 years ago
    #1 8 years ago
    Even though it's not usually called out on the schematics, Gottlieb did intend for flasher bulbs (455s) to be used in certain spots on the backbox. Sometimes there's an indication on the schematic, but usually you have to go by the bulb socket. One way to tell is whether the socket is flush with the wood on the front of the insert panel. They're placed flush to better accommodate the round globe of the 455s. But this can be hard to tell sometimes.
    Another quick way to tell is to look at the sockets from the backside of the panel. The sockets used for the flasher bulbs are different than the ones used for the 44s (or 47s). Note that they have a 'button' style back, whereas the sockets for the regular bulbs have an exposed spring.
    The two types are shown in this picture.
    Gottlieb bulb socket typesGottlieb bulb socket types
    So when in doubt about whether a flasher bulb was intended or not, the bulb socket itself tells the story.
    #3 8 years ago
    Great advice DF thks
    #4 8 years ago
    Is there any ideas on why the sockets are different? Pre wired sockets on the assembly line?
    #5 8 years ago
    Good tip! Thanks!
    #6 8 years ago
    vs.
    WWDFD?
    #7 8 years ago
    Which manufacturer had the beveled holes in the front of the panel to allow the globe shape of the 455? Was that Bally?
    #8 8 years ago
    Love this! Always wondered where they should go / if they should go. Thanks.
    #9 8 years ago
    Ok, I wanted to put flashers in my Sing Along..... In the backglass behind the MUSIC sign. So, I have to first check the socket..... I'm new to the hobby and just thought I could place them wherever I wanted!
    #10 8 years ago
    I have them in my Sing Along in that very spot. Can't remember if they are identified that way in the schematic but they definitely fit.
    #11 8 years ago
    Same on my Sing Along - I saw them flashing there on Vic Camp's machine, so I copied the flasher placement.
    Will be nice to know if it was original!
    #12 8 years ago
    Quoted from Budman:
    You can as long as there's room.
    #13 8 years ago
    Quoted from Cash_Riprock:
    or bevel the edges of the holes to allow for bulb clearance.
    #14 8 years ago
    Here's what the front of the sockets look like, showing the difference between a "flush" mount for the flasher bulb, and the regular recessed socket for the normal bulbs.
    #15 8 years ago
    Nice tip!
    #16 8 years ago
    My score reel lights look weird on Melody . What kind of bulbs are they? Sockets are different from normal 44/47 's
    #17 8 years ago
    Quoted from 1974DeltaQueen:
    Probably a wedge base instead of bayonet? I think those are a 555.
    #18 8 years ago
    My Atlantis has flashers behind "Atlantis" on the BG, but the sockets are "normal", and not flush. Is it safe to assume someone thought it looked cool and simply inserted flashers? It does look great, and I wouldn't change it, but just wondering if the above guidance is universally true.
    #19 8 years ago
    Quoted from pocketscience:
    I don't think Dirt is suggesting you *have* to put them in a certain place, just that the factory installed sockets for them. I have and will continue to put flashers where I think they look good by modifying the wood to fit them.
    #20 8 years ago
    think you might be onto something there
    just checked my Card Wizz, flasher socket was on the lamp behind the magicians flash
