This has me totally baffled. When the playfield is up for service
flipper is not energized and they work normal. As soon as I lower
playfield and metal hooks behind apron make contact with cabinet support
frame flipper energizes. All wires are clear and I have check them all.
Replaced Eos and coil. Disconnected right flipper switch and it stays
energized. There must be a relay switch stuck thats feeding this coil.
When frame makes contact with the cabinet it complets the circuit.. Any
idea which relay energizes the flippers. Diring game startup flipper doesnot energize until at the end of start up sequence. Thanks
