On the later gottliebs, the score motor is held in by hairpin clips, so you can tilt it up to be able to better access some of the switches around it. On my Flipper Clown, I need to clean/adjust/possibly replace the innermost switch on stack 1a, and this score motor looks like it's glued or screwed down to the bottom board, but underneath the bottom board, there are no bolts or screws.
I see 3 screws but only have easy access to one of them. What is the easiest way to remove an older Gottlieb Score motor, or to at least tilt it up so I can see how to change out this switch?
-Pat
