(Topic ID: 139016)
Em tech Cabinet Medic
By 1974DeltaQueen
8 years ago
  • 15 posts
  • 9 Pinsiders participating
  • Latest reply 8 years ago by boilerman
#1 8 years ago
How do I safely remove the bottom panel on a Wedgehead? Do's and don'ts . Remove the back and slide in new wood sounds simple but I'm thinking I go do more bad than good by removing 44 year old glued wood that is built like a brick outhouse .
#3 8 years ago
If it is solid, why change it?
I have hurd some cut the lip on the back, "less obvious" and slide it out.
Others cut all 4 lips, and install trim all around new board to secure.
I think as long as you cannot see it when done, whutever works for you.
#4 8 years ago
I cut the rear lip & pulled it out. Worked pretty well.
#6 8 years ago
Ok I think I like the cut the rear lip method if I go that route. The issue is some assclown replaced the front third of the bottom panel with an advertising sign at some point. If I'm going to put 30-40 hours into a rotisserie cabinet paint I'm at least going to have original looking wood on the bottom inside the under the coin box.
#7 8 years ago
Here's the hard way to do it, cut away the side rail and slide in a new bottom panel.
To be honest, side lip needed replacing.
And a little touch up paint almost good as new
#8 8 years ago
I sprayed webbing into the thinner on the hf touchup gun and it coagulated into a little rubber glop NFH
#9 8 years ago
Quoted from 1974DeltaQueen:
I always spray the webbing in first then cut it...
#10 8 years ago
Yep, found that out the hard way, now I got rubber cemented to the sides of the bottle. Don't forget I'm NOT in Texas, I'm from the cold northeast, was in the 60's when I tried your trick. I will figure it out eventually.
#11 8 years ago
How not to do webbing. Just posted to ebay
#12 8 years ago
#13 8 years ago
Ooh, that's ugly!
#14 8 years ago
That looks awful. The rest of the paint job looks nice.
#15 8 years ago
I would rather see NO webbing than to much. it just jumps out and slaps you in the face.
the only game that had super thick webbing was bank a ball, most pre 67 had really fine webbing. you could not see it well if you were standing a few feet away. that KoD you could see the webbing from 1000 ft away
Space Coast Pinball
Other
The Pinball Scientist
Protection
Decals
Other
$ 8.00
Led
Apparel - Unisex
ArcadeMade
Unisex
This page was printed from https://pinside.com/pinball/forum/topic/em-tech-cabinet-medic and we tried optimising it for printing. Some page elements may have been deliberately hidden.
