Have a confusing problem with a 2-player Bally Hokus Pokus. After cleaning up the high-current contacts, adjusting spinners, etc., the game isn't starting up properly. Got it to where it goes thru a reset/startup sequence. After the score reels reset, the tilt relay activates and ball counter continues to count up to the 3rd (or 5th) ball and then hits Game Over, all continuously. (Ball is removed while testing.)
The tilt circuit does seem to be shorted--continuity between tilt bob and ring bracket. Checked the connector for the tilt mech and still a short there between the tilt bob wire and ground, so it's not the tilt mech itself. Any idea where the short might be? We reseated all connectors, looked for a short, found nothing. Didn't mess with the reset motor/cams/switchbanks!
For a while the start button would only count down a credit, then we manually held the reset and interlock relays and got it to cycle. After a while, the credit button would go thru startup but continue counting up the balls until Game Over. Checked the contacts and clearances on the relevant relays--reset, ball count, tilt, lock, etc. Any ideas?
