(Topic ID: 217268)
EM TECH: Bally Mushroom Bumper Bypass Hack
By TheCnyPinGuy
5 years ago
#1 5 years ago
Hello
Working on a Bally Gator 69
I noticed an Extra Mystery Wire (see pics) that was run out to the MB #5
So I traced the Wire up to the playfield and sure enough it goes to the MB#4 Mushroom Bumper PF Switch
So when you operate either MB 4 or 5 but Shares The MB#5 Relay (normal operation from 5 sw and hack from 4 sw)
I cut the extra wire that was run out from the MB4 playfield switch to MB5 relay to make game back to factory specs and the MB4 Playfield Sw does not make the MB4 Relay Fire as it should
So I’m assuming it broke years ago and this was a quick fix ...
However after looking
I can manually engage the MB4 relay and scores etc but the playfield Sw does not operate its relay
How do I test one of these 3 lug small size coils ?
All switches are clean and properly adjusted - the extra wire had most likely Been here for 20yrs or better but I want the game to work correctly
Thank you
B4A4D166-6F06-46D6-8548-E636A8FAD748 (resized).jpegB4A4D166-6F06-46D6-8548-E636A8FAD748 (resized).jpeg
0E2ACEE0-B296-4721-B24C-8EDEFDA852A7 (resized).jpeg0E2ACEE0-B296-4721-B24C-8EDEFDA852A7 (resized).jpeg
F54B9D85-38DB-447C-A649-669C596047EA (resized).jpegF54B9D85-38DB-447C-A649-669C596047EA (resized).jpeg
03DF68E4-23C6-45E3-8B0F-D0C97D868604 (resized).jpeg03DF68E4-23C6-45E3-8B0F-D0C97D868604 (resized).jpeg
#2 5 years ago
Quoted from TheCnyPinGuy:
The most reliable way is to swap with a working coil, but you could also use an Alligator clip jumper wire.
#3 5 years ago
I did the jumper to the following relay to test to coil etc
With the jumper the 4 and 5 MB fire
So the MB4 coil seems to work BUT when I remove the jumper it doesn’t work
I will lift out the mech panel today and look at what might be wrong
Will follow up later on
If any ideas please just let me know
James
#4 5 years ago
In your other thread we looked a little into this hack. At one point it looked like there might be a 2nd out of place wire (a brown jumper). (Refer to https://pinside.com/pinball/forum/topic/em-tech-69-bally-gator-4-player-game-issue#post-4392588) Did you ever establish whether that wire was supposed to be there or not? If you haven't already done so I'd go through all the wires that touch the 3 solder lugs on the MB 4 and MB 5 relays to make sure they're all in the schematic (in the link above) and wired correctly. You've established that one wire was out of place. It's not hard to imagine that there'd be another.
/Mark
#5 5 years ago
Hi Mark
Digging in there now to see what is what
Doesn’t seem to difficult to figure out using the working Mushroom Relays on how it should function
Will follow up
Yes that Brown small jumper appears to be out of place as one end was not attached to anything but compared to all other relays def seems out of place . .
#6 5 years ago
After looking the brown wire serves no purpose I snipped it out and I’m still in the same spot I have been at
Still moving forward
This page was printed from https://pinside.com/pinball/forum/topic/em-tech-bally-mushroom-bumper-bypass-hack and we tried optimising it for printing. Some page elements may have been deliberately hidden.
