Hey Thanks Mopar!!
The next testing I will perform is a score motor bearing run-out test. Sounds crazy right? The cams attached to the score motor shaft can be moved side to side and show that the score motor end bearing has a small amount of play. Here is my theory, I think this could maybe throw off the timing of the score motor switches 1A and 3B. Switch 1A and 3B both need to close at the same time when the motor rotates around to the third tooth of cog A. (according to this general motor timing chart below anyways) in order to energize the tilt reset coil. I'm going to try putting a side load on the motor shaft to see if this changes the tilt reset function. So things may get better, worse or stay the same. We shall see. Stay tuned.
Really wish I could find the elusive motor switch timing chart for this game.
