(Topic ID: 228622)
EM score motor cam missing teeth - ideas?
By n1teowl
5 years ago
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 5 years ago by n1teowl
    #1 5 years ago
    I've got a Williams EM that was not scoring right. The 3000 point switch was scoring 2000 and the 5000 point switch was scoring 4000. It turns out that two of the teeth (one on each side) of the impulse score motor cam were broken off. I'd prefer to replace the cam, but I know I will have a hard time finding one. Any ideas for a fix? Should I try to melt something on? I also thought about drilling a hole below and looping some stiff wire around. What's the best approach?
    #2 5 years ago
    No patches will reliably solve this. The best option would be to replace the part. If one can't be found, perhaps a replacement can be fabricated.
    #3 5 years ago
    As Em`s get older, this is something that there might a market for, I thought I had a bunch of G10 around but I think they got tossed.
    I would try to drill the center of the nub with a 1/32nd bit, after filing it flat first, (leave as much material as you can tho), find a small piece of G10 fiberglass or similar, drill the same thru the piece, insert a piece of wire (paperclip) thru the new piece and into the wheel, using epoxy or your glue of choice, then shape to contour of original
    Have never done this, but it is what I would try first
    Good luck
    #4 5 years ago
    Sounds like a great 3D printer project.
    In the mean time, I’d put a chunk of JB weld plastic on it and file it down to form it.
    #5 5 years ago
    Look on ebay for part or buy cheap parts machine..
    #6 5 years ago
    Thanks for the ideas. I have JB Weld as well as some some fiberglass fabric. I figure it's worth a try to fix it - worst case it can be fabricated, 3d printed, or replaced. I might try a combination of drilling, adding wire and then JB weld. I'll post some pics and let you know how it goes!
    -1
    #7 5 years ago
    If the broken disc is removable I can fab a replacement. PM me if it comes to that.
    #8 5 years ago
    I used wire and JB Weld, just curing now. LateCenturyMods - thanks a ton for the offer. Fingers crossed that I won't need it.
    #9 5 years ago
    What is the tooth count and diameter? I’m pretty sure I have a replacement
    Mike V
    #10 5 years ago
    Diameter is 2 inches not including teeth. There are two sets of 5 teeth (for a total of 10), with what looks like a 1 tooth space in between.
    #11 5 years ago
    Success! I ended up drilling a small hole and threading some wire through. I twisted it tight and cut it off. I then spread some JB Weld on and let it set. After that I filed it smooth and reinstalled. Working great now, but it remains to be seen how well it lasts. Thanks for chiming in, everyone.
    20181103_120404 (resized).jpg20181103_120404 (resized).jpg20181103_121509 (resized).jpg20181103_121509 (resized).jpg20181103_180912 (resized).jpg20181103_180912 (resized).jpg
    #12 5 years ago
    Here’s one if you want it
    652CE2EF-42C0-4C85-9B95-D9089A8EF34D (resized).jpeg652CE2EF-42C0-4C85-9B95-D9089A8EF34D (resized).jpeg1A98EC68-3BCD-4891-ABE4-867F8A93121D (resized).jpeg1A98EC68-3BCD-4891-ABE4-867F8A93121D (resized).jpeg
    #13 5 years ago
    That's it! I'm sure yours will hold up much better than my hacked one. Thanks a ton for finding it. I'll PM you.
    #14 5 years ago
    I had the same problem with my Big Injun, one of the teeth was missing on the player unit in the backbox so it would always skip a beat and add 2 player game, somehow, but luckily i found the missing tooth in the bottom of the cab (right before i vacuumed it even) so i could just hard glue it back, now the game works fine again.
    #15 5 years ago
    definitely doable as a 3d printed part in solid Nylon
    I designed this for a guy and put it up at Shapeways
    https://www.shapeways.com/product/E2ES3LJ4Z/pinball-drive-wheel-03-8476-tz-bop?optionId=55148176&li=marketplace
    #16 5 years ago
    Thanks RacingPin for getting me that replacement part. I appreciate it!
    This page was printed from https://pinside.com/pinball/forum/topic/em-score-motor-cam-missing-teeth-ideas and we tried optimising it for printing. Some page elements may have been deliberately hidden.
