Quoted from bingopodcast:Oh, was your switch dirty? Why grind the contacts or sand them with your metal wheel (did anyone mention doing that)? Why not just adjust the switch?
Switch was clean and wiping well with good pressure. However, it was one of those edge cases. Some contacts can be a bit pointy on the surface area, which I suspect might have been the case. Then again, I've seen this happen with well-formed contacts too... so I don't know. Maybe 1 out of every 200-300 pairs just needs a little extra persuasion/adjustment. Unfortunately, it just happened to occur on THIS particular switch, which was obviously one of the worst places for that to happen.
In hindsight, a good thing. Now it definitely won't happen again.
Quoted from bingopodcast:Question for you - what happens with and without your mod when a score reel coil is detached on one side (and cannot move)? The answer is you are still vulnerable.
True, but this is the case for all EM's, isn't it? At least the fix removes a large variable from the "things to go awry" list. At least seven coils could lock this way, possibly more. Might as well do it.
Quoted from EMsInKC:For what? A problem that basically isnt a problem?
In global IT circles, we refer to these issues as "vulnerabilities" and deploy "hotfixes" to remedy them. This would qualify as such.
