Quoted from xsvtoys:I did draw it completely from scratch. For this project I used Adobe Animate, which was formerly known as Flash. Other possibilities to do it in vector format could be Microsoft Visio or LibreOffice Draw. I don't think I would attempt something of that scale in a bitmap format.
I use Flash for a number of reasons. First, I have been using it for many years so I am very familiar with it. It is known as an 2D animation tool which it does very well, but it is also an underrated vector drawing tool. Once you get the hang of it, you can work quickly in the vector environment. A key feature is the ability to draw something once, then save it to a library as an object. This is critical for any situation where you need to use the same object over and over. You can then just pull it from the library any time you need it and place it where you want. So that is great for drawing things like switches that are used over and over in one of these schematics.
All that said, I wouldn't recommend it unless it was something you were really interested in doing and really desire the end result. It is quite a bit of work, even if you are experienced. Once I started this one I couldn't stop of course, but man it took a long time to finish. These pinball schematics are full of quite a bit of information. The Flash file is quite large, and it has more than a dozen layers. You have to be organized and focused on the details to get it done right. I did do it in sections, and I tried to be as careful as could be as I went along, but even then I would come back to it and spot obvious errors I made. You can drive yourself crazy putting in all of those wire colors and switch numbers.
I recommend having a look at the redrawn Bally Wizard schematic which is uploaded at IPDB. That one is particularly nice IMO. I don't know who made that, or how they did it, but it would be interesting to know how that one was made. Particularly notable is that all of the wires are drawn in their actual colors. In theory it should be somewhat easy to do this in Flash/Animate as you should be able to one-click a line and change its color, but I haven't found an easy way to make the 2-color dashed lines and that is the main reason I didn't do it.
PS if anyone does have access to the latest version of Adobe Animate I can send the native FLA file if you want to see it. PM me an email address. The file is 22MB in size.
What an awesome guide! I found this by coincidence since a friend of mine has a Monte Carlo from 73, which when only playing 1 player, randomly anvances to player 2 after a ball has drained.
Sometimes even when ball 2 drains, it could be advenced to player 3s score field... Hopefully this can shine some light onto why that could happen even thou he only insert 1 coin.
Thanks alot for taking your time and writing this!!
Regards from Sweden
