I have an Old Chicago that does not send the ball to the shooter after it falls in the outhole. I see a leaf switch underneath where the ball goes that I can close and it will send the ball as it should. The problem is that there is no way for the ball to touch the leaf switch. It seems to be mounted about 1/2 inch aside from directly underneath the ball return where I would imagine it should be. It doesn't look like it ever has been modified and that it has always been there. Is there a piece that I'm missing? Thank you very much for your help.
