(Topic ID: 144315)
EM - HELP - Gottlieb, Star Trek, 1971, EM
By E_N_3
8 years ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 8 years ago by Toyguy
#1 8 years ago
I was cleaning an EM, Gottlieb, Star Trek (1971), for a customer, and I ran in to a bit of a pickle. I am not well versed in the EM world, and as such, I am begging the gods of the EM repair to help me figure the issue out.
When I started everything, the game worked fine, and just needed a cleaning, and rubbering, etc.
I turned the game off and started swapping out all of the bulbs, which I made sure to do with the power OFF! Once I had all the new bulbs in (LED ... I know, Iknow, but it's what he wanted), I turned the power on and the bulbs in the head were fine, but the PLAYFIELD lamps were really, really dim (almost unnamable that they were on). I started a game and the PF lamps immediately dimmed and went off.
I thought that maybe the LEDs were causing an issue, so I put all incandescent bulbs (I checked that they all worked before putting them in). Nothing. I found the 10amp fuse for the PF lamps was blown, so I replaced it. PF lights are on again, but again nearly unnamable they are on. Start a game, pop, fuse blows. I look everywhere, and nothing seems loose or touching. I keep touching various wires and replacing the fuse and ... POP. again and again.
The odd thing is that the rest of the game is working PERFECTLY. The game plays, all of the PF switches/targets work, register, score, etc. The game zero's fine, and the backbox lamps are working perfect.
So, basically, everything, aside from the PF lamps, is working.
Please, please, please, help.
I can post the wiring diagram if needed, as it was folded up in the bottom of the game.
the attached pic is of the area the fuse was that keeps popping. It is the 10amp one in the MIDDLE (fuse is removed in the pic)
thanks,
--ed
#2 8 years ago
You probably created a short when you put in the LED bulbs. It's easy to do. A leaf on one of the bayonet sockets turned/bent just the wrong amount, and it can touch something it shouldn't. Pop goes the 10-amp fuse.
Go back and inspect every bulb you changed. Look for leaves touching metal.
#3 8 years ago
thanks leckmeck.
Just to confirm, when you say "leaf", you mean the two small tabs that are at the base of the socket, or do you mean the "S" arm that the socket sits on and that connects to the PF?
thanks a million kajillion!
--Ed
#4 8 years ago
Where the colored, cloth-covered wire attaches to the tab of the socket. When those bend and short against the socket itself, poof! - fuse blows.
#5 8 years ago
I've actually had a bad LED bulb blow a transistor on a board with a solid state before. So if all the sockets check out alright and you haven't shorted the actual sockets, it could be that you have a bad bulb somewhere as well.
#6 8 years ago
Does it pop with no bulbs installed?
#7 8 years ago
DirtFlipper: perfect... thanks! I will check that out. I bet that is the case, as I moved a few down when installing the bulbs from the underside.
u2sean: oh man, that stinks! I know that such things can happen when changing bulbs with the power on, which is why I made sure to turn the game off while installing -- especially since it isn't my game, it belongs to a customer. I am hoping that the fact that it is an EM, I didn't do any major damage, such as your blowing the transistor board. I guess that the same thing that makes EM a pain is the same that make them good -- no "boards" -- lol
Toyguy: good question ... I don't know. I can test it this week and let you know. If it does/doesn't, what is it indicating?
Thanks a million, again, to all who have (and still may) send ANY advice/info my way!
--Ed
#8 8 years ago
Ok, so i went back and checked every socket, and removed all the bulbs from the PF. Still no luck.
I did notice that if i put LEDs in some sockets, and hit a pop bumper or something, i could get the bulbs to flash as the bumper actuated..but they wouldnt stay on no matter what i tried.
#9 8 years ago
So the playfield lights fuse still blows with no bulbs left anywhere in the playfield? If so, then that suggests there's a hard short (metal to metal) in that path. Still need to keep carefully examining.
#10 8 years ago
Does the fact that the lamps will flicker on than off with something like a pop bumper "thump" help with tracing anything?
#11 8 years ago
Maybe check for possible shorts in the coin door.
#12 8 years ago
Woah! I think you are on to something ith the coin door suggestion! tell me more about the coin door! I was messing with the coin door and found that somebody had previously cut some wires in there and i took the electric tape off, twisted the wires back togethwr, and got the short to stop blowing the fuse. Now it is down to just the lights not going on, instead of the lights going on dimmly and then blowing the fuse a few seconds later.
#13 8 years ago
IT was just a hunch
I own a Astro, but fortunately have not had this particular short problem on this game,
but have had shorts in the coin door on other pins in the past.
keep picking away at it
you will eventually figure it out or trace it down.
#14 8 years ago
Also check where the pop bumper light leads come out near the coil mount bracket. There should be some plastic insulation over the lead that passes near the bracket to keep it from shorting out.
Playfield - Plastics
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/em-help-gottlieb-star-trek-1971-em and we tried optimising it for printing. Some page elements may have been deliberately hidden.
