Attached is an image of the right flipper that is starting to act floppy.
1) The brown wiring looks like someone split lamp cord and ran it to the EOS. This is also present on the left flipper. Is this okay?
2) The placement of the brown wiring is reversed on the soldering to the EOS leaf stack than that of the right flipper. Looking at the picture, you see that brown wiring runs from the far right terminal to the right/(bottom)leaf contact on the EOS. This is switched on the left flipper arrangement. Does the wiring polarity on the EOS stack matter?
Thank you!
