Anyone ever have a bakelite material/rivet receding issue?
Curious what you think the best option to go with? short of another less worn unit.
Here is what I have ,the continuity of the shoe to contact rivet is sometimes hit or miss,so I was thinking of drilling a small dimple hole in the center of the tubular rivets of which some are below the level of the bakelite material.
Thinking of soldering new contacts over the existing ones, bringing the height of the rivet to normal level.
Anyone see any good or bad doing this type of repair,or have done one?
Either going to use the gold flashed contacts or the tungsten type contacts Pbr sells for their leaf switches to make this repair.
Was thinking new shoe springs would push them closer to the contact rivet? But it still would feel like a pothole for the rotating shoe avoiding continuity.
I have adjusted the assembly as close as possible,using spacer washers which helped a little but still not enough for good contact.
Any input would be appreciated.
Thanks, Pin-it
