Just new to the site and hope someone can help. I have a Bally Miss America Deluxe, had it for many years and it has worked great with no issues. Had not played it in a while. Started and played game and it seemed the magic lines did not work. At the end of game started a buzzing and I “bumped “it and caused a tilt (most likely the tilt bob) and it apparently blew the 10amp 50 circuit fuse. I replaced fuse and when I plug in it immediately blows fuse. So as I started to troubleshoot, every time I try to start up the fuse blows. I got a 5amp breaker to further try to find fault. On doing a (dark room) test the anti-cheat relay sparked on the part that says it goes to trip relay. I put paper in this contact and it still blows fuse. Also after the fuse blows I held down actuator and this caused the tilt light to go out and relights the numbers on the cards. Also the button safety relay pulls in and holds when I hold anti-cheat relay down. I put a 9 volt battery to all the coils and they pull in,but the anti-cheat relay does test at 1.9 ohms. I don’t think that is causing the spark in the leaf springs though. I hope some of you can help!
