(Topic ID: 129748)
EM backbox hack or feature?
By Boatshoe
8 years ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 8 years ago by MikeO
#1 8 years ago
Hi, I'm working on my first EM, and I noticed these dark black rectangles that I supposed might have been rubber at some point, but now just feel like crusty toast. Are these supposed to be here? Did someone modify the backbox in an attempt to protect the backglass?
I filed 2 off, but was afraid to continue. Although they are only 1-2mm deep, they press right up against the backglass and I was not sure if they were serving any function.
#2 8 years ago
Those are the remnants of foam strips (pretty much like weather stripping), used to cushion the backglass. You can get similar foam from Lowes/Home Depot and replace.
#3 8 years ago
Remnants of the factory foam rubber strips. Normal.
#4 8 years ago
Thanks guys.
#5 8 years ago
Quoted from KenLayton:
As are the marks they left on the back glass.
#6 8 years ago
Don't replace these with foam. Use cork or felt instead. Over time, the foam reacts with the backglass ink and discolors it. Foam breaks down over time. Felt is probably the best replacement.
#7 8 years ago
You know, someone gave me a tip on replacing that with the fuzzy side of an adhesive Velcro strip. I have yet to try it but it sounds promising.
#8 8 years ago
Felt sounds pretty good. I was thinking even some electrical tape would work. It is such a thin layer. I was afraid foam might be too thick.
I won't be able to put the backglass back in for awhile (I am repairing a lot of the game) but I appreciate the suggestions!
#9 8 years ago
Quoted from Boatshoe:
I won't be able to but the backglass back in for awhile (I am repairing a lot of the game) but I appreciate the suggestions!
I wouldn't use electrical tape. It's too thin to do any good, and the adhesive can eventually leak out toward the edges of the tape and gum up your glass. I think a strip of felt and a dab of glue would be best for cushioning the backglass.
#10 8 years ago
Quoted from dasvis:
This would be a simple solution but my concern is that the loop side of velcro could be too thick and bind/strain/stress the glass.
Quoted from jrpinball:
This is what I use. I take thin 3/4" wide felt weather stripping, which is maybe 1/8" thick and split it to about 1/16" thick and apply it to the head relay board with double sided sticky cellophane tape. It works quite well. I've found the 1/8" thick felt is too thick and can also bind/strain/stress the glass like I'm concerned the loop side of velcro might and that is why I split it thinner. A better solution could be if they make 1/16" thick felt weather stripping or just use black craft felting material cut to size.
Cabinet Parts
Space Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/em-backbox-hack-or-feature and we tried optimising it for printing. Some page elements may have been deliberately hidden.
