Quoted from javagrind888:
So I'm setting up my new speakers and light kit and I got a serious snag. Whoever installed this screw tightened it so hard they completely stripped it out. Normally I'd go buy a stripped screw bit, but the screw is so small and there's no clearance for a drill. There's also no clearance for a Dremel tool to cut it. Any ideas?
Tried the rubber band method.
Get a good screw driver and put pressure like if you were pushing the screw in and start rotating slowly. If you are using a good screw driver it will come off. just be careful with the monitor.
