(Topic ID: 252126)
Elvira's House of Horrors - The Owner's Club
By RobertWinter
  • 18,130 posts
  • 1,019 Pinsiders participating
  • Latest reply 1 hour ago by EaglePin
  • Topic is favorited by 458 Pinsiders
Topic poll
“Do you currently own other Elvira machines?”
  • This is my frst Elvira machine 493 votes
    69%
  • Also own Elvira and the Party Monsters 41 votes
    6%
  • Also own Scared Stiff 118 votes
    17%
  • I own all three now! 61 votes
    9%
(713 votes)
27 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 18,130 posts in this topic. You are on page 96 of 363.
#4751 3 years ago
Quoted from javagrind888:
I got the 5.25" speakers in the mail. The speakers came with wires that clip on but don't have the plastic connector. Do I just desolder the wires off the 4" speakers and just solder them on the new speakers?
Yeah...de-solder the wires from the original speakers and solder them onto the new speakers. Be mindful of the + and - connections.
I'm not really sure when Stern started adding that small molex disconnect on the speaker connections, but I know they were not there on all of the SPIKE 2 games. They make it nice for temporarily unhooking the speakers if they need to be removed for some reason....but for replacing them, not so much as the de-soldering and soldering is still needed for swapping in replacements.
#4752 3 years ago
yes you can do that, what I did was to order the connecter and solder that onto the new speakers that way I can swap stock back in if I want too. The Kenwoods come with a nice cable that you can crimp the connector on too.
Neil.
#4753 3 years ago
Yes. Be sure to change the impedance in your audio settings to match.
#4754 3 years ago
Quoted from dudah:
Good thing you pointed this out. What do they need to be switched to?
#4755 3 years ago
If you bought 4ohm speakers switch it 4ohm and hear the difference. If you leave it at 8ohms the speakers will sound a bit louder then the 4ohm setting but 4ohm should sound crisper. FYI you can use 4ohm speakers at 4 or 8 ohm settings.
#4756 3 years ago
Quoted from DeathHimself:
4 ohms. Found it on the box.
Is there an ohm setting for the cabinet sub also? Bought that too.
If you can't tell I never went through the usual speaker fetish during my younger years.
#4757 3 years ago
It's in the game Utilities menu, audio maybe... then select back box speaker type and switch it to 4ohm.
Too be clear on my last post, I said you can run 4ohm speakers at 8ohms. In the past this would cause the amps to heat up too much and damage the amp. In recent years many electronics have upgraded quite a bit and has become a non issue on a lot of high end equipment. Now lets keep in mind were talking about Sterns china built boards lol, so in theory you shouldn't for you may or may not have an issue but I run mine at 8ohm just for that is what sounds better to me.
#4758 3 years ago
got the bone flippers with purple rubbers, and purple plastic protectors on...looks so nice
#4759 3 years ago
Quoted from Muymanwell:
You need to paint those. Do a bit of weathering.
#4760 3 years ago
Quoted from PeterG:
ya, i saw others paintwash theirs...i may do that
#4761 3 years ago
Marco is now sold out of the flippers.
Will they restock/are they still being made?
#4762 3 years ago
Quoted from dudah:
There is still a set to be had on ebay but they are $10.00 more then Marco had them..
ebay.com link: Bally Scared Stiff Pinball Boney Flipper Set 20 10343 NOS
#4763 3 years ago
Quoted from dudah:
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PPS-20-10343
this is where i got mine
#4764 3 years ago
Does anyone have a lead on a NIB Elvira? I have one on order but was told Jan - Feb before Stern makes more. Sites that have them listed don't really have them. Thanks!
#4765 3 years ago
having a new issue where the backdoor is tripping 3-4 times in a row.. or when I hit the garage lock (sometimes) it will trigger...
Thoughts?
#4766 3 years ago
Quoted from TTARider:
Thoughts?
check the optos positions and if they are loose, maybe it's real close to being out of alignment and vibration moves the beam enough to open the circuit and register.
#4767 3 years ago
Quoted from wtatumjr:
ebay.com link: NEW Stern Elvira House Of Horrors Premium Pinball Machine Ships October
that's who i bought from. no headaches, no issues. ordered saturday, had it by wednesday, free shipping.
#4768 3 years ago
Flipper power on my Elvira just started dropping noticeably. This is my first pin so any help is appreciated. Stops seems solid so should I try to adjust my switches?
#4769 3 years ago
Quoted from UnholySpectacle:
Could be bad coil stops. Seems to be a fairly common problem on recent Sterns.
#4770 3 years ago
ebay.com link » New Stern Elvira House Of Horrors Premium Pinball Machine Ships October
Same here.. bought mine on a wednesday night, it shipped the next morning and was in my home by friday!
#4771 3 years ago
Try pinballs.com (call them) thats where i got mine
#4772 3 years ago
I tried the link and it adds $533 tax. Any sites tax free?
#4773 3 years ago
Quoted from xbmanx:
Agreed, call Mike and talk with him. According to his site he has 2 left right now.
#4774 3 years ago
So a bit of a weird issue here. May have been already discussed.
If the cellar has a ball in the vuk and then another ball enters the back-door.. that ball then stays on the small step before the vuk. The vuk fires the 1st ball out but the other ball doesn't fall into the cellar vuk... the vuk thinks there's a ball needing to be fired out so fires off until there's the malfunction message.
Pic shows the ball on the edge of the vuk but won't drop in. You can just make out the edge of the ball up the back.
I then painfully have to go into diagnostics, open the cellar then fire off the vuk after shaking the ball off the step into the vuk... is this possibly a simple pitch issue? All the optos are registering fine and everything works well unless 2 balls get caught in the cellar at once. Any solutions would be greatly appreciated.
#4775 3 years ago
Quoted from John1210:
if you manually place a ball at the back door, does it easily roll down into the chute? if not, you may need adjust the metal piece of the VUK back a bit to widen the gap to allow the balls going in there more easily.
Super exclusive ad from the Pinside Marketplace!
#4776 3 years ago
Yeah if I place a single ball it goes down fine intovthe vuk every time but if there is already another ball in the vuk to prevent it, it stays on that backdoor step before the vuk as in pic... evan a strong shake doesnt move it. I may try adjusting metal piece like you suggested and see whT happens. Thanks for the suggestion.
The vuk goes into auto fire bout 10 times before it shuts off... with the ball on that tier not dropping in. Stuffs up the whole game unfortunately
#4777 3 years ago
I know of some NIB LE and SLEs available.
#4778 3 years ago
Quoted from docquest:
Coil stops seem fine but I just changed the one on the right flipper and it is still the same weak flip.
#4779 3 years ago
I just ordered from Mike at Pinballs.com. Gave me 2.5% discount for cash but charges for shipping so it comes out about even. Thanks everyone! Now I have to figure out how to tell my wife I have this and Attack from Mars remake on order.
#4780 3 years ago
So I'm setting up my new speakers and light kit and I got a serious snag. Whoever installed this screw tightened it so hard they completely stripped it out. Normally I'd go buy a stripped screw bit, but the screw is so small and there's no clearance for a drill. There's also no clearance for a Dremel tool to cut it. Any ideas?
Tried the rubber band method.
#4781 3 years ago
Try a pair small vise grips.
#4783 3 years ago
Could you use a cutting wheel on a dremel to cut a slot in the screw head then use a flat blade screw driver in that slot to unscrew it.
#4784 3 years ago
Space is too small. Going to try buying a screw extractor and a drill bit extender. Maybe that will work. Will be a bit at an angle though.
#4785 3 years ago
No it isn't, hold the Dremel parallel to the front of the speaker panel and cut a slot to use a flathead.
#4786 3 years ago
That's kind of an odd ball type / size screw from what I have seen. This is the only direct replacement, I believe, I have found on the internet:
https://www.boltdepot.com/Product-Details.aspx?product=26832
I actually expected the shipping on a single screw would really sting on getting a replacement (I was expecting a near $20 min shipping charge), but for me and my location...they actually have $4.95 shipping available. Not bad if someone would need a replacement.
#4787 3 years ago
Apologies as im sure this has been covered... Is there a section in this thread to deal with house ramp reject fixes? Getting them regularly... seems when its a fast direct hit it rejects.
My flippers do feel a little too strong but couldn't find a flipper strength setting in menus. Is there a way to dial them down.cheers
#4788 3 years ago
Finally got a video of the skull flasher dome with lit eyes I put together as well as the zombie and spider. They look pretty sweet in action.
#4789 3 years ago
Quoted from Pinstein:
Finally got a video of the skull flasher dome with lit eyes I put together as well as the zombie and spider. The look pretty sweet in action.
Looks great!!
#4790 3 years ago
Yes to all, go to game specific settings, and go backwards as flipper strength is typically towards the end. Also , as of recently I reduced pitch which drastically reduced ramp rejects. In my case I went from 7 down to 6.6 or so. It greatly reduced them.
teddyb73 reported the same findings, so props to him if it works for you.
#4791 3 years ago
might be covered here but just picked up a premium, added the side armor, new speakers,light up speakers and inner blades. any other must haves for this game? also any tips on glare from the light up speakers?
#4792 3 years ago
Quoted from whoknowsgoi:
Absolutely required:
https://pinside.com/pinball/forum/topic/elvira-3-interactive-casket-gargoyle-vuk-cover-medisinyl-mods/
#4793 3 years ago
Shaker is really well integrated. Bent plastics might help glare. If you bought lights from speaker light kits, they are dimmable
#4794 3 years ago
Quoted from jandrea95:
Great thanks for the tips.
#4795 3 years ago
I realize this is being greedy, but I wonder if there is a code drop soon? The last Stern if the Union indicated as much for August, but it never came out AFAIK
EDIT: duh. Yes it did, .99 halfway into August
18
#4796 3 years ago
Hello! I just joined the club. I purchased LE #181! I now have all 3 Elvira pins.
#4797 3 years ago
Quoted from Elvira:
You had to buy it? I would have thought Stern would give you one for all the work you did
#4798 3 years ago
Awesome to see that Stern released a trailer for the new Avengers that shows the topper and other planned accessories.
Makes me wish they would release details on the Elvira topper.
#4799 3 years ago
Any tips , the house sometimes rejects shots in it?
#4800 3 years ago
What is your pitch setting at? try 6.5' or even 6.3' and you will get a lot less rejects
$ 50.00
Don's Pinball Swag Barn
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 200.00
Led Pinball
PWM Designs
Docquest Pinball Mods
8,499 (OBO)
Hollywood, FL
$ 1,099.00
Paradise Distribution
$ 47.00
Space Coast Pinball
$ 99.99
Maine Home Recreation
$ 36.00
Pin Monk
Playfield - Plastics
SilverBall Designs
$ 130.00
Dijohn
9,500
$ 1,075.00
Orange County Pinballs
$ 60.00
Inscribed Solutions
$ 29.99
Cento Creations
$ 69.99
Inscribed Solutions
SilverBall Designs
$ 50.00
Duke Pinball
$ 31.99
Cento Creations
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/elvira-s-house-of-horrors-the-owner-s-club/page/96 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
