Quoted from dschulpius:
Thanks for the advice. I have tried adjusting the VAK power in the menu for the DH eject. I found the best setting I could at that time. I'll tinker with it again to see if I can get it set closer. I have not bent the VAC hood yet. I'll try that next. Also I'll try to loosen up the bracket and move it around a little to see if I can get it centered better. Thanks.
This Dead Head Crypt eject design looks a lot like the DE Star Trek 25th computer hole eject setup. Same solenoid bracket. That damn ST25 computer hole has plagued me for years on my ST25 pin. It most always ejects the ball STDM when it ejects the ball. When I saw that bracket on my Elvira HOH I about lost it.
Make sure you try both bending it up (to widen the gap) and down when you test. The curve of the hood has to be within a certain range. Too tight And the ball can't escape but also too loose and the ball will hit the hood awkwardly and fall back down
