Quoted from vikeking27:I have this same issue, and there is a post covering a number of options to try to tackle it - personally, I'm going to take that bracket off and just trim that crimped rod down with an angle grinder. It really just needs a couple more mm of clearance to not catch on it - should be able to strike a balance between that and making sure the rod can't slide through.
Post 133985 - thanks mbwalker
Thanks @vikeking27. When I ground down mine, I thought I had it licked. Nope - just to much slop in everything. Try to gently turn the gargoyle to make it worse by hand and scoot the ramp to left and see if it hangs up. Don't force anything, instead you're just trying to simulate game play. Bending the left tab outward helped a fair amount to limit how much play is in the pin.
I also loosed up the screw topside and tried tried to bias the gargoyle to help, but there's a notch it sets in on the backside of the PF that limits how much you can adjust. Plus it bumps against metal guide topside. But every little bit helps get margin.
Topside I swapped the philips head bolt with an hex head - just made it easier to snug it down. Used a little bit of blue Loctite since I had some setting around.
