Quoted from Rob_G:It's a bug related to trailer trash countdown. A similar bug was fixed in .97, but I guess not completely? I was able to reproduce it the first time I tried, but not since.
Rob
I figured out a way to consistently reproduce it.
Steps:
- Start a new game.
- Start Teenagers From Outer Space (top left window).
- Get to the final shot where the beast booster and final shot are lit.
- Hit the beast booster until the lower value on the screen ends in 500
- Complete the haunt.
- Start Trailer Trash.
- Hit one ramp
- Then shoot the center shot (completing Trailer trash)
Blam-o! A 5 point shot. Here is a video of me doing it three times in a row:
My theory:
During Teenagers From Outer Space, before making the final shot to complete the haunt. The spinner is lit to increase the jackpot. Hitting that spinner will make the final shot value either end in 500 or 000 (watch the lower number).
When that value is 500. Trailer trash seems to calculated by starting at 50% of the value of that final lower score (or that score is added to be part of the final score), with the ramps each adding 25%. Hence, 25% of 500 is 125. So if you only shoot one ramp and the final shot, your at 75% the score which will give you that 5 pointer (more specifically a 375 pointer).
When that value ends in an even thousand (000). Everything works fine. As 25% of 1000 is 250.
Hence, the bug isn't actually with the countdown of the trailer trash. It's with the point value calculation.
I hope that information helps!
Edit: I updated this post to include more accurate information as I discovered it.
