Quoted from dschulpius:Thanks for the advice. I took the crypt house assembly completely apart to see what was going on. You are correct. There is no way to get it to close completely without something scraping, breaking or bumping. However I did remove the opto bracket and added three #4 washers under each hole while I had it apart. That was enough to close the gap more then half way and everything clears nicely. More then the three washers caused the skull to hit the front of the house and the opto blinder to bind inside of the "U" optos. It actually looks much better now and I cant see the skull's jaw anymore. Just a sliver of light. I'm good with that. Thanks again.
pics? It'd be nice to compare your crypt to mine.
