Elvira and the party monsters.
Lower pop bumper quit working. I found a burned transistor at Q77. Replaced it, no difference. I tested the transistor, it reads the same as all the others. I tested the traces and all the way back to the coil and it has continuity. There is power at the coil, and if I ground the coil it fires. The switch registers.
I'm at a loss, any suggestions?
