My friend has an Elvira LE that is having some issues. It is already on the newest code
First off the crypt, once activated it starts moving and never really stops. The nut to hold it tight came loose but hell if I can get it tightened in the right place that it doesn't bind up. In test it doesn't activate the switch at the up position, even if I hold the motor. Hoping someone can explain how this thing is supposed to be secured, maybe even share a picture.
Second when hitting the right flipper button the lights on the game change, it happens in attract mode as well. First press lights up all inserts, second all gi, third all flashers, fourth returns to normal operation and then it repeats. Each stage of this light show is stacked so when the inserts, gi and flashers are all lit up it is blinding. Regardless this is not how the game is supposed to function. Anyone have any ideas here? Time to contact the distributor?
