(Topic ID: 243276)
Elvira and the Party Monsters Playfield Swap/Refresh
By dmacy
1 year ago
  • 79 posts
  • 14 Pinsiders participating
  • Latest reply 54 days ago by alexmogil
  • Topic is favorited by 23 Pinsiders
There have been 343 images uploaded to this topic. (View topic image gallery).
46A2358D-F1FE-49AB-A108-27B9FD4EA7E0 (resized).jpeg (© Nutty 5.0)
CD4D08FB-C653-4252-B9F2-776E41554A3D (resized).jpeg (© Nutty 5.0)
FF82323D-990B-46D3-9B84-6B653394D622 (resized).jpeg (© Nutty 5.0)
57405F76-01EE-4991-9247-8FE0AF6716C0 (resized).jpeg (© Nutty 5.0)
C21515F9-43BE-42A1-A69F-D513CA44EEC6 (resized).jpeg (© Nutty 5.0)
C854EA6B-6253-4950-AE66-B2832AEE322B (resized).jpeg (© Nutty 5.0)
D79F9BD2-F4C3-467C-BF77-F6B6A6C54BA7 (resized).jpeg (© Nutty 5.0)
CD084595-3C79-438A-B3CF-D0B16DC71364 (resized).jpeg (© Nutty 5.0)
7A0DC32F-6BFF-4BE6-ABD1-E86499455C72 (resized).jpeg (© Nutty 5.0)
597CBAA0-2913-4B0C-9A32-0A7232547B92 (resized).jpeg (© Nutty 5.0)
8F3E8ED3-1765-4AF7-B6FE-829EEE962AA9 (resized).jpeg (© Nutty 5.0)
598BF6C3-0508-451E-BE59-22E3D86DDB3D (resized).jpeg (© Nutty 5.0)
B7A64866-8D55-4928-833E-9A3FBEC49920 (resized).jpeg (© Nutty 5.0)
5ABA58FA-B11C-434D-AE1A-82543AFC7A22 (resized).jpeg (© Nutty 5.0)
DFF52845-67F2-4488-83D5-78F56FA45E0A (resized).jpeg (© Nutty 5.0)
5D459883-DE4E-41AE-BB73-E96B2BC8A1CD (resized).jpeg (© Nutty 5.0)
There are 79 posts in this topic. You are on page 2 of 2.
#51 1 year ago
Damn, how did I miss this thread.
Anyway, it looks awesome, as usual.
I have four games that have been re-done by dmacy and he does kick ass work.
#52 1 year ago
Quoted from Mitch:
Really enjoy following this thread
Great work so far.
What are you doing with the old playfield? Would you sell it?
It’s not mine to sell but I’m sure he’ll reach out if he wants to sell it.
#53 1 year ago
Quoted from Spyderturbo007:
I’m still waiting for you to get those Velcro gloves back out!
#54 1 year ago
Lamp harness is completely placed and installed. Solenoid harness is placed and flashers are fastened.
My least favorite part in process: switch replacement. 2 down. Too many to go.
B3C5CB15-50F4-4B69-8D11-2922471A08D2 (resized).jpegFDC93951-80CA-41A2-9472-44868B3C8043 (resized).jpeg79826C0B-3D4C-4413-8276-41C42661C93C (resized).jpeg9E0C8165-985E-4BAD-A747-32783EC3215A (resized).jpeg93621331-58DB-44F6-ADE0-86DFFD63341A (resized).jpeg
#55 1 year ago
Quoted from dmacy:
Dibs via PM on May 24!
Either way this thread is helping me prepare for when I eventually shop out my EATPM, playfield swap or not.
#56 1 year ago
Quoted from Gornkleschnitzer:
Yes, you were the first. The owner isn’t sure if he’s keeping it yet. But the playfield will be with me not going anywhere until the swap is done.
#57 1 year ago
Note on this title: There’s a pair of diodes by each slingshot GI lamp. Diodes and tubing replaced.
6E5878E8-CC87-4D1B-9E91-A4E1427FFB39 (resized).jpeg24939849-D914-45FE-B442-FBE57D564A18 (resized).jpeg8B350F22-2EB5-41CB-AFED-CF49343D6C5A (resized).jpeg649E9052-82D0-43C9-9DE3-65271C3B8002 (resized).jpeg
#58 1 year ago
Switch replacements never seem to end! About 2/3 through the playfield switches at this point. There’s still more fun coming when doing the ramp switches!
My method for installing switches on the playfield regardless of (good or bad dimpling):
First compare with original playfield line up.
Then line up the switch close to original line up on new playfield. I square and line up centering the switch to line up the best as it can.
Using a spring loaded/automatic center punch, mark the holes.
Then use your drill and bit (make sure to use a drill stop and check it’s gap regularly along with a smaller drill bit than the screw size!) and drill.
Install the switch making sure to be centered and cinch down by hand. The last part is checking the switch by the click sound and with a ball. You really can’t adjust them correctly IMHO without a ball. There may be a few you’ll need to test with playfield installed and powered up. But I’ve found this method for me to be best and usually requires little to no adjustments once installed.
A1F58517-E620-4846-96D8-A98F415B88B3 (resized).jpeg2094EC3F-B059-47AC-B3C3-0A611F3D61FE (resized).jpeg0887C1D5-9D69-4D54-908F-47D4A344CB92 (resized).jpeg5B19BD14-2B30-4171-A75C-71B8092F8910 (resized).jpeg96514D2E-A478-4CDA-8B53-BE0F664AE33B (resized).jpegEE897114-7B66-4DB2-B8D8-BEF571BC431C (resized).jpegC7DA9709-86CB-4748-B4BB-8F92EA1449A7 (resized).jpeg61199CB8-9DBD-47DC-BF1A-C1A66FF43066 (resized).jpeg3ABF6913-C9AD-46FF-AAAD-15E039AF08E2 (resized).jpeg82ABEBAF-B81A-4854-B15A-C54240F57E3A (resized).jpeg
#59 1 year ago
Everyone has there own method of installing which harness first. I’ve done it all different ways. Most titles seem to be working best for me to install the GI/insert lamp harness first. I’ve had so many of the yellow solid GI wiring get brittle and break doing it last so I like to get it out of the way.
Solenoid harness usually second so I can get flash lamps installed. This can be tricky to do last I’ve found snaking to coils and soldering. YMMV.
Switch harness last because that works best for me. Often I have targets already installed so the harness is pretty sparse. On this one, the targets and decals are in good shape so we’re not replacing. Just the microswitches and pop switches.
Progress today:
#60 1 year ago
Took a liberty with this plastic. Have seen others that just have the screw but not stud with nut. Changed to what plastic uses but note this may not be as designed. Easily changed back if wanted.
Before and after:
450716E0-AD3C-4E90-9F71-011BC2E4AA9D (resized).jpeg9D779E91-0976-4D94-BA7F-8A952A2ED888 (resized).jpeg
#61 1 year ago
Here’s the playfield with all the switches replaced and installed. All the switches have been tested with balls: ball locks, ball trough, inland, outlines, etc.
Some of these switches, like sling switches, will get the second screw installed in play testing.
We are getting pretty close underside. Pop switches and solenoid wiring needs done.
C670FE88-F921-4040-97F2-3006B8D56878 (resized).jpegD725A034-40B5-4825-A38C-349C15CF97B4 (resized).jpeg
8F5257D7-97BF-4DEA-B481-77188A6BD1A6 (resized).jpegBCEF3A5D-5EC7-4882-A028-98DC5D2157D7 (resized).jpeg931C7D46-DD93-4506-AB34-ED197134284F (resized).jpeg1ED3BB2F-856A-4A9D-8992-C227533220CE (resized).jpeg
#62 1 year ago
GI testing before it comes off the rotisserie. Almost done other than the very bottom back coils, switches and some wire management.
For now, we are filling CT’s kit for playfield GI. Frosted cools, a few red and greens. They may change, but they all look good and working.
F81A2DFA-9DC9-42E1-AAC6-C25235EF2FBA (resized).jpegAF584DCD-814D-4A0C-9A4F-5104466F0D77 (resized).jpeg8FDA72D7-B3A4-4E0E-BFE1-4A130FD4ED01 (resized).jpeg1F580712-62CF-4D1B-BD17-6F8A62FEE90C (resized).jpeg57EF1A9F-E02F-4C95-9E92-5D3E2E7BB9B6 (resized).jpeg1A14EFCA-61DB-48E9-BB67-45249636AE3A (resized).jpegC30B1532-EBD0-4BF5-B3A2-90A94BE612B7 (resized).jpegC5E2885C-AAA1-4CB4-B11D-D1AF304C38DD (resized).jpegC98C4578-2A4D-43FB-96A1-9AB38CA074C2 (resized).jpegF15A1972-8DB9-48A3-963C-CCE298B6F3F7 (resized).jpeg
#63 1 year ago
Beautiful job
#64 1 year ago
Ok, now I need to order a spring loaded center punch...great tip
#65 1 year ago
Quoted from cosmokramer:
I can’t take credit for the punch as someone else shared it. But it is perfect and makes a nice dent that is easily seen and drill bit falls into it.
#66 1 year ago
We made contact! It fell in, well not literally, but unlike some playfields this one went in not tight (neither did original) but perfect. It doesn’t bind and is smooth moving up and down. The front brackets needed minor adjustments to land but that’s expected.
AAB254F0-6CC7-4839-B360-1D6C72147CB6 (resized).jpeg2741464E-28DA-4D34-9727-57DE8935A9CC (resized).jpeg5E57B663-D5C1-44AA-BEE7-245F92934C71 (resized).jpeg01D37FDD-62D5-4B5D-904C-5D62316783E3 (resized).jpeg29AABE39-F97B-4C48-8E9A-CA26E15747DE (resized).jpegE33D5BD3-37A3-4712-B1FF-14EB4A2FD65B (resized).jpeg5BED832C-002C-43FB-815B-9383F28FE288 (resized).jpeg8A659D32-CD35-44A7-8FD2-45F6EC0A28CB (resized).jpeg
#67 1 year ago
Here's the 5 large post locations. Two 4.5" posts, one 4.5" hex post, one 3.5" post, and one 3.25" post. I had to open up a few of the round post holes that have studs going through the playfield. Not much, but slightly so worth mentioning.
Sorry for the bad drawing but you get what you pay for!
#68 1 year ago
Boogie Mech Bracket: it was cracked but hard to tell until the coil was removed. Apparently this is pretty common and it is pretty thin gauge. Some small L brackets with JB Weld. Would be great if someone had a bracket to see if Kerry from Mantis could replicate. I'd think most all of them out there will need one.
#69 1 year ago
i love this thread
#70 12 months ago
She lives! A few trough adjustments, replacing a bad cement resistor at R9 on interconnect board, and it’s 100%.
Still play testing and tweaking but so far it’s super brutal fast and playing great.
DFF52845-67F2-4488-83D5-78F56FA45E0A (resized).jpeg5ABA58FA-B11C-434D-AE1A-82543AFC7A22 (resized).jpeg598BF6C3-0508-451E-BE59-22E3D86DDB3D (resized).jpegB7A64866-8D55-4928-833E-9A3FBEC49920 (resized).jpeg5D459883-DE4E-41AE-BB73-E96B2BC8A1CD (resized).jpeg
#71 12 months ago
Made some more tweaks today. The left ramp flap was remade to be longer on both sides. The new ramp had rivet that was too long and the balled up slack caused extra thickness and the ramp flap being so short had a bulge.
Also went with the original skull as it looks way more detailed. He repro looks good and fits great and even glow in the dark. Ended up trimming off the front right support at ramp as it was broken and were concerned it would just crack again if repaired. So it was trimmed off like the repro and sanded down.
597CBAA0-2913-4B0C-9A32-0A7232547B92 (resized).jpegC854EA6B-6253-4950-AE66-B2832AEE322B (resized).jpegCD084595-3C79-438A-B3CF-D0B16DC71364 (resized).jpeg7A0DC32F-6BFF-4BE6-ABD1-E86499455C72 (resized).jpeg8F3E8ED3-1765-4AF7-B6FE-829EEE962AA9 (resized).jpegD79F9BD2-F4C3-467C-BF77-F6B6A6C54BA7 (resized).jpegC21515F9-43BE-42A1-A69F-D513CA44EEC6 (resized).jpeg
#72 12 months ago
Finished up with boogie monsters installed. Final switches adjusted, and latest ROMS installed.
57405F76-01EE-4991-9247-8FE0AF6716C0 (resized).jpegFF82323D-990B-46D3-9B84-6B653394D622 (resized).jpegCD4D08FB-C653-4252-B9F2-776E41554A3D (resized).jpeg46A2358D-F1FE-49AB-A108-27B9FD4EA7E0 (resized).jpeg
#73 12 months ago
It looks so shiny.
Kick as job, as always!
10 months later
#74 56 days ago
Quoted from dmacy:
Making some progress. Thanks to taylorva we have rails installed.[quoted image][quoted image][quoted image][quoted image][quoted image]
Where did you get new jam drop target decals? I have looked everywhere and have had no luck.just finished Harlem globetrotters restoration and about to start my elvira and this is the only thing I need.
#75 55 days ago
I believe they were provided to me.
#76 55 days ago
Quoted from radfordian3505:
I may have a set. About the only thing i didn't replace on mine when i had her. She's gone now but i MIGHT have a set. I will try and remember to check tonight. PM me later today to remind me..
#77 55 days ago
Quoted from Bohdi:
Oh thank you so much. Will message for sure bro.
#78 55 days ago
I checked. Don't have them. I have the BBQ decals. I knew I had some just wasn't sure which ones. Sorry..
3,250
Greenville, NC
$ 18.99
$ 399.95
Pin Stadium Pinball LEDs
$ 79.95
Medina, OH
