Quoted from SKWilson:
Yeah. My turret only turned during a ball search. Wouldn't turn in diagnostics, either.
Odd, my roof turns in diagnostics to all 4 locations. Via the diagnostic screen specifically designed to test the roof.
Strange. My roof turns to all 4 positions in the diagnostic screen that specifically tests the roof.
Quoted from tmntrule999:
I apologize if this has already been talked about, but has anyone gotten or seen any official flyer of this machine?
I'm hoping to snatch one up at the Wheeling Expo. Actually two. One for my collection and one to put up in my office.
Quoted from FtrMech:
Yep, it did during the Stream...trying to showcase features no doubt and then maybe pulled it for whatever reason...I am not concerned, the machine is certainly playable/enjoyable as is. I believe it is just a matter of time before we see updated code...IMO, this machine has plenty of potential and we are only scratching the surface...absolutely no regrets.
Me neither. Since we know Lyman is on this I can’t imagine it won’t turn out great.
They sure rushed these out
Some pieces still had protective plastic on it
( I removed one then took the pic- left top corner) any one else also ?
Also chip out of one of the legs
Strange looking metal piece right top corner sticking out but does not seem to hit the ball , by a mm
Quoted from rvdv:
Strange looking metal piece right top corner sticking out but does not seem to hit the ball , by a mm[quoted image][quoted image][quoted image][quoted image]
I think the plastic on the LE label is normal and a good thing. That metal piece sticking out in your corner is not good. Looks like you’re going to have to remove the plastic piece and readjust that metal piece underneath it.
Also it is a real screened mirrored backglass and you can feel and see the layers of the texture on the back, it is not a laminate decal. Game looks amazing in person !
Quoted from mnpinball:
Don’t know if it’s been mentioned or brought up but quite impressed with the Elvira cabinet thus far, the bottom of the base cabinet is a 13 layer 3/4” plywood. Very solid.[quoted image]
Cabinets have been like that since Munsters Le - solid ply base, proper corner brackets, even laminated sides. Rock solid. About time Stern improved cabinet quality on these expensive games. Great to see it has continued on Jurassic Park Le’s and 3lvira.
Quoted from CVeRiTy:
Yes, I updated from the 0.80 it shipped with to the latest version via USB and had no problems.
Interesting
Tried twice. Same USB I use for all other games. Keeps saying wrong spk file.
Magicchiz
Quoted from Magicchiz:
Interesting
Magicchiz
similar thing happening with the latest ghostbusters update, lots of people having trouble
Interesting
Magicchiz
Did you unpack the zip with windows built in unzip function?
Well, crap. There must be something wrong with my turret. It did light up, however, when I got to the Attic Party last night. I'll have to check it out along with my lockdown bar button which quit working. Fun.
Quoted from vireland:
Yes
Not sure if this will make a difference, but this works for me...
A couple things to note:
- I trust 7-Zip more than other unzip tools
- I only download and unzip on a primary hard drive, and then copy to the USB drive
--- basically avoid doing operations on the USB Drive - only copy the files onto it when they are ready
- Keep the USB drive empty, other than the update files
Do not do that. Use winrar or some 3rd party add-on to unzip the file. Stern warned about unreliable files if you use the built-in windows unzip like 2 or 3 years ago. I have no idea WHY there's a problem, but there is for some files on some machines. If you use a winrar or something like that, problem solved.
It's likely your issue.
Interesting
Magicchiz
Did you formatt the USB before dragging the files over? Could be a dud USB drive as well. Try a new USB. That has been our issue a couple of times.
Quoted from rvdv:
Protective tape over scratch-sensitive parts is normal (and appreciated). Mine also has the metal piece, it's the corner of an L shaped supporting bracket. Less than ideal that it extends onto the art, but doesn't seem to cause any problems.
Well finally had to do the SD card image in order to update my Elvira 3 LE. I tried different USB sticks. Tried Winzip, winrar and windows and none of them worked. Alas the SD card image did. Been updating games for a long time and this is the first one that has given me trouble.
Magicchiz
Quoted from pinball_mutha:
Has anyone heard when premiums are going to ship?
November
Quoted from cleanandlevel:
or SLEs?
Also November from what my distributor told me.
Quoted from rvdv:
Few odds things on the game , one is I can start a new game by pushing the lock bar button ?
All new Sterns have that as default. You can change it in settings.
Quoted from GamerRick:
Thank you
That’s new to me
Quoted from rvdv:
Thank you
That’s new to me
The button will also plunge the ball unless disabled in settings. Both of those (start & plunge) I turned off once I leaned over the machine (GOTG) and launched a ball prematurely.
I've been told that premature ball launches is something that just happens as you get older.
Mine should be shipping soon, I have to pick up. Does anyone know if I can load it ‘in box’ into the back of a pickup bed with canopy, or does this need to be unboxed prior?
Quoted from Mogg:
If the opening to the truck bed is more than 32", it should fit in the box.
This is my first Spike2 Stern.
Is there any difference between updating via SD card vs USB?
I mean, I understand the difference. But is there any difference in the final outcome? Is it just that doing the SD card gives you a clean, fresh install?
Will updating via USB still take care of updating the node board firmware, if applicable?
Quoted from moonduckie78:
No difference in the final outcome as far as game code/game play is concerned.
Updating by USB will update node board firmware as required.
USB should be fine in almost all circumstances - each update also updates the necessary node boards. You usually only re-image an SD card when it's borked/corrupted. Not that common of an occurance.
I have been playing mt EHOH since it arrived Wednesday...lots to do and I really love it. I am thinking the shots are much easier than in my Munsters...I can easily back hand the Dead Head Crypt, the Front Door is a reasonable shot, as expected...I am experiencing rejects from the garage as well as a several SDTM returns on failed garage shots but it is an easy shot to make...regardless, this game is a lot of fun...can't wait for the next code update.
Quoted from jfh:
What if you update with a new sd card image only would that still update the node boards if needed?
If you do the SD card route, you lose all your settings and scores.
Quoted from Pinballpal:
Yes. But I wouldn’t mess with an SD card update unless there’s a good reason to do so. USB update is a lot less hassle
What do owners think of the sound? In the streams I’ve seen it sounds very repetitive/ monotonous. Is that just my imagination?
Quoted from jfh:
Just remember the code is still being developed. Believe me, there is a lot of stuff missing. What's there is great!
