(Topic ID: 217633)
Elektra pinball - keeps blowing F3 fuse
By tslawson107
1 year ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by BigAl56
    #1 1 year ago
    Bally Elektra worked for years then blew the 4 amp fuse on the rectifier board assembly (AS-2518-54) repeatedly. Since the board was in bad shape, replaced the entire board with a new one. As soon as I powered it back up, blew the same fuse. Logic tells me to swim upstream and replace the transformer (AS-3071-2). Does this seem like the next logical move?
    #2 1 year ago
    I think the power is coming from a bridge rectifier or 4 diodes to that fuse.
    Test those .
    #3 1 year ago
    Don't replace the transformer, something downstream from the fuse is overloading it and causing it to blow.
    As wariodolby said, first test the four diodes at CR5, CR6, CR7 and CR8 on the rectifier board if any are short circuited.
    If you don't have a multimeter or don't know how to test diodes then with the machine off, disconnect the J3 connector from the rectifier board in the base of the cabinet and replace the 4A fuse at F3. This disconnects the circuit downstream from those diodes.
    If the fuse blows on powerup, the problem is one of those diodes. If the fuse does not blow, the fault is even further downstream at the solenoid driver board in the backbox.
    #4 1 year ago
    Since F4 blew before you replaced the board the problem is downstream as Quench suggests, First thing you need to do is look at the schematic and determine what does F4 do.
    Hint.......
    Give up? .....
    F4 is for the 43v solenoid bus. You probably have a blown coil on the playfield. Unplug the playfield connector from the PS and see if the fuse blows. If not start checking all the playfield coils.
    1 month later
    #5 1 year ago
    Quoted from BigAl56:
    Hint.......
    Give up? .....
    What if it does blow? I'm trouble shooting a different machine and seems to be the same problem,solenoid fuse blew out of nowhere and now blows every time the game is powered up.
    #6 1 year ago
    Do you have a 4A circuit breaker? This sounds like a decent amount of searching and I'd rather click a switch every time it pops instead of replace the fuse. Might pay for itself in the first few minutes.
    #7 1 year ago
    Not that im aware of it's on a Caribbean Cruise (gtlb sys3) and it's blowing an 8a fuse
    #8 1 year ago
    You can narrow it down by unplugging the other connectors but generally speaking if f4 blows right away on power up it's probably a shorted bridge.
    $ 21.95
    Apparel - Unisex
    Pinball Wheezer
    $ 999.00
    $ 69.99
    $ 16.00
    Tools
    PinballSolutions.eu
    $ 234.99
    $ 16.00
    $ 24.75
    The MOD Couple
    $ 64.00
    $ 39.00
    $ 150.00
    Republic Of Pinball
    $ 26.50
    $ 90.00
    € 59.80
    Lighting - Backbox
    Freddys Pinball Paradise
    $ 65.00
    G-Money Mods
    CzTV Mods
    $ 34.95
    $ 29.95
    Pinball Photos
    $ 16.95
    $ 157.00
