I've been collecting info to create a Tech Chart for Bally - Elektra.
After going through the manual and schematics, I found an error or so I think.
I found two thyristor designations for "Tilt", but there is only one Tilt lamp behind the back glass.
I'm missing the designations for the saucer hole (top and right) "Shoot Again".
My guess would be that the wroung labeled "Tilt" lamp is actualy the "Shoot Again" lamp(s) connection.
Here is where your help comes in....
Where does the wire from A9J3-17 (Aux. lamp driver board) go to? Wire color should be 38 (Yel-Blk).
Is it indeed the Tilt lamp?
The commonly used connection for the Tilt lamp has a Yel-Wht wire and comes from A5J2-10.
Which wire color is used for the "Shoot Again" lamps at the top saucer and the right saucer?
Where does it connect on the lamp driver board? Or is it the Aux. lamp driver board?
Perhaps it is A9J3-17 ((code 38) Yel-Blk)?
The attached file is for all the lamps I've found with help of the manual/schematics.
Peter
www.inkochnito.nl
