(Topic ID: 189848)
Electro-Mechanical Cleopatra Restoration Project (Finished)
By Shiny_balls
6 years ago
There are 82 posts in this topic. You are on page 1 of 2.
#1 6 years ago
Sorry buddies, I took a break from Williams Fire! project for Cleopatra EM......started this week!
I wanted to make my machine looks new as it came out from factory like this.....
But of course, cabinet will be much better quality finish than the factory.....
Both numbers from cabinet and backbox are matched but what the......looks different
Made from separate factories? Backbox has much more spatters than main cabinet......
Bad sanding job at the factory.....will fill it with bondo to make it straight.....
Bye-bye to old metal bottom
Sorry, I didn't like masonite bottom panel (or MDF)....I'll change it to a nice plywood bottom....
To like these....
A spacer for backbox has wrong grain direction on front side.....probably bondo or wood veneer.....
My playfield.....
Damaged from right hole kick.....
Left hole kick........
Damaged from left slingshot....
#2 6 years ago
I look forward to you progress reports. I love this game in the EM form. Can I ask how you remove the bottom board? Are they just glued in on Gottlieb EM's. Good luck.
#3 6 years ago
I'll be following this as well!
#4 6 years ago
Drew the artworks on tracing papers for homemade stencils later....
No need tracing papers, just measurements....
Cut off bottom at the back to remove bottom panel and make a rabbet with router for new plywood filler....
Repairs loosely plywood...
Straight edge as a guide for bondo......
New plywood sheet for bottom and 3/4 ply with rabbet as a filler....
#5 6 years ago
I'll use RustOleum Lobster Red spray can for red stencils (I did for Royal Flush and Super Spin) and createx paints to match purple....with an airbrush.
Close enough, I wanted a little lighter purple, tested with clearcoat.
Aged purple looks nice (green arrow) but I'll go for brand new looks.
I'm done with purple mix before losing the original purple color forever...
Top edge at the back not flushed, another small rabbet for wood filler....with a router.
Filled with a pine wood......bondo, sand, bondo, sand, bondo....
Remember, sanding the old cabinet is dangerous, wear a Respirator Mask.
590ba66a-873b-4a24-8dbc-cfb156bc20a1_1000 (resized).jpg590ba66a-873b-4a24-8dbc-cfb156bc20a1_1000 (resized).jpg
Open the gap with chisel and filling in with glue, nail it with 18ga brads..... every joint around the backbox....
#6 6 years ago
Bondo, sand, bondo, sand....OK, cabinet is done for now........
Time to clear the bottom to avoid get dirty again.....with a HVLP spray gun.
Put a straight edge guide on crooked edge and bondo......
b4d2b74f8aa17a6955500d5b85a4a2c303c04f37 (resized).jpgb4d2b74f8aa17a6955500d5b85a4a2c303c04f37 (resized).jpg
Bondo on back to metal door......
Bottom edge of backbox....
2 coats of clear dried and a bit of caulking.....
#7 6 years ago
Sanding the surfaces of a backbox is done, see the nice, very sharp corners...but I'll sand very small round corners with 220 grit....
Small round corners......
Spacer for backbox, I added a veneer to rotate the grain direction by 90 degree on front side.
Bottom side masked....
A quart of oil-based primer...$8.88 from Lowe's.....one part of primer and about 2/3-3/4 of thinner to mix for a HVLP spray gun....
I'll turn the cabinets up side down after dry, then to finish the rest of primer coats.
After priming job, I'll look for defects and bondo for the last time.
#8 6 years ago
Lots of small defects....hard to see without primer.....no problem, more bondo!
On the next day, sand off the bondo with 220 grit....
Sanding job is done....
Drill 1/16 holes for nylon cabinet glides...(not too deep)
See the filler I installed on the bottom? perfect flushed!
Back of cabinet, can't see 2 fillers on top and bottom....
Second primer coat.....
Making stencils, on large glass top coffee table, tracing paper is under the poster paper...lamp is under the glass top.....
#9 6 years ago
Sanding the fine orange peel finish primer into smooth surface with 400 grit
A bit of caulking inside corners.......
Sorry, bad picture, original 45 degree bevel on back edge of backbox was too large and rough, I had to bondo on all 4 edges, sanded off square and then smaller bevel...
I'm going to paint the white base with Rust-Oleum "Painter's Touch 2x" spray cans... "Blossom White"
Firstly, spray the back edges of backbox and a bit inside to metal door...
Half an hour later, I put temporary legs on with 18ga brads....
Turn upside down to spray the rest....
White base job on backbox is done.
Cabinet done.
Zinsser oil based primer and Blossom White are really almost same color, primer is matte, Blossom is satin finish.....less dirty when I move the cabinet around a lot....easy to wipe off.
One coat of Blossom is good enough for me, 2 and a 3/4 cans for one coat.
Blossom White and a piece of A4 white paper folded in half together......
#10 6 years ago
I use this half pint water based paint for splatter....flat black
ff5d36b1-516a-4621-8460-080643de654e_1000 (resized).jpgff5d36b1-516a-4621-8460-080643de654e_1000 (resized).jpg
Add some water to make it thins and into a HVLP spray gun at very very low pressure.....
Testing, testing, testing....on a cardboard....
All done in less than 2 minutes....fast! .....in nice cool early morning, because I don't want to adjust again and screw up...
I'm happy, it looked the same as my other machines...Royal Flush and Super Spin.
I can remove unwanted spots easily with a razor blade.....
I'm going to cut the stencils with a X-Acto knife all day today.....
#11 6 years ago
A drywall leftover....as a cutting board.....
Poster paper isn't thick but easy to cut.....
Red Lobster paint on cabinet....ahh.... all good
I put large washers and nuts to hold down the poster paper.....
Half an hour after spray job, I removed the washers and nuts but leave the stencil on....
Stencil raised slightly itself or stick on wet paint with your finger and lift.... and then spray it.... a quick, very very lightly....to get some under spray...
Not all of it, wherever I like....horse feet, ear, pyramid...
Gloss paint is thick, it raised a bit....I don't like it....I'll take care of it with clearcoats after stencil job.
Backbox.....Oh baby... yeah!.....looks good.
some has very narrow stencil, I had to put pins in to hold down...
A black spot on her lip...eww... tried to remove with a razor blade....
Will try again tomorrow, paint still wet.....
#12 6 years ago
Beautiful work so far!
#13 6 years ago
Commenting to follow. Great work! Really appreciate all the close-up, in-focus, photography!!!
#14 6 years ago
Yeah! Fantastic pics and tips, thanks!
#15 6 years ago
Thanks guys.
I need another Red Lobster spray can but couldn't find it in stock, I had to order it at Home Depot.....
a case of 6 cans (sigh) and I have to wait few days to pick it up....
I still have 1/3 -1/2 spray can left but couldn't spray the large area face down....but I can do small red on coin door area and a red line on front backbox....
I have looked at purple sample to make sure if I like it......Yep, I liked it
Paint it purple with an airbrush......
Front backbox is done.
Coin door front is done.
A box of stainless steel screws has arrived.....for side rails.....no nails for me.
I'll replace the phillip screws for slotted on my other Gottlieb machines
ebay.com link: Slotted pan Head Sheet Metal Tapping Screw Stainless Steel 4X5 8 Qty 100
#16 6 years ago
While I'm waiting for Lobster Red paint, I'm doing the playfield a bit....
There is a lump under each facetted post, not going to sand flat.....just a drop of glue into hole and hit it right in the center few times until it flatted with a ball pein hammer.....and let it dry.....
I'm done with magic eraser and alcohol, can't do anymore....or lose numbers and letterings...
Nice lime green color, will repaint all.....also purple too....
Glue covered the hole, may not find it after repaint and clearcoats.....drill it before paint job.
Some #8 screws are little too long....(depend on what brackets) will see some lumps on playfield...I'll cut the tip about 1/16 off with a bench grinder before reinstall....some, not all of them....
I'll change the inserts.....white and purple only.
White inserts are hard to find....from 3 places...
Old inserts need to be scanned for waterslide decals
Bondo on some spots.....
#17 6 years ago
GREAT work so far. Inspiring
#18 6 years ago
Quoted from Shiny_balls:
Wow, that's quite the difference!
Still enjoying the Cleo show. Keep it up, Shiny.
#19 6 years ago
Bonus value area is done (inside blue line)
All hand painted....
Black - 10-25% (1 coat)
Yellow - 98% (3-4 coats)
White - 100% (3 coats)
Red - 0%
Purple - 99% (2 coats)
Daylight pic...
Old pic....
Waterslide decals for black ring inserts after a coat of 2pac clear.
Going to Home Depot to pick up Lobster Red spray cans.....
#20 6 years ago
Working on the cabinets now......
All red stencils finished this morning....
Today, purple on large cabinet.....OMFG....looks fantastic!!
Yippeee!! Very happy!!
#23 6 years ago
Createx is water based paint.... the stencil paper can be buckled a bit if spraying a few coats...so, I painted the stencil paper to make it like a waterproof with any oil-based spray can....for Createx paint.
Sometime under spray doesn't looks good.....scrub it out with wet cotton swab...(for Createx paints).
For oil based spray can....let it dry and then scrape it off with a razor blade. If you clean it off with thinner, it will stains the white base paint...permanently!
I'm going to clear it with 2PAC, same stuff for playfield.....no, no, I'm not going to make a high end pinball cabinet.......just the stencil sides only...to knock down the stencil paint edges.....
One face up at a time, blue tape around.....
Cover it up with papers....and check for defect black specks, remove with razor blade.....
I paid $95 plus tax for both gallon and quart at the local store....(4 part and 1 part to mix)
Yep, it's toxic and very dangerous, read first on Vid's guide....
Yeah, it has small orange peel finish...but I'm not worry, I'll wet sand it perfect flat and smooth.....
See the raised stencil edges? red is thicker than purple...I'll wait for a day before wet sand.
#24 6 years ago
After 2 coat and wet sanded with 400 grit....the raised edges are going down but I'm afraid to sand any more......looks like I didn't spray thick enough....well, one more coat.
Just like my other projects, Royal Flush and Super Spin.... I did 3 coats each side.
I sprayed this left side of backbox much thicker than the cabinet......after wet sanded, looks like almost done....with few unmarked spots....
OK, on 3rd coat, I'll spray the cabinet more thicker and less on backbox.
Final coat and wet sanding with 600 grit....
Ah there's an unmarked spot.... sand more
Carefully, sanding on bevel with fingers
No more unmarked spots.... all gone!
2PAC job done on one side...... perfectly flat and smooth.
Turned over to other side to repeat 3 times....
Ewww...look at gloss red , matt purple and satin white.... looks awful without clearcoats....
I will do the same thing on Williams Fire! project later....2PAC over artworks...to knock down the vinyl decal edges!!!!
#25 6 years ago
Wow what a great job. Keep the updates coming.
#26 6 years ago
I'm still salivating over here. Nice work. Any chance we could see a close-up of those pinholes left behind by the needles (the ones that hold the stencil in place) after they've been clear-coated?
#27 6 years ago
Close up masking tape detail....
Second coat, wet sanded and cleaned up this morning........
Third and final coat for right sides only this morning........
Quoted from RyanClaytor:
Before and after pictures for Mr Ryan Clayor....
Before clearcoats......
6ddc42d65a8e23f9b1c409d51b8b895b4c3b28e4 (resized).jpg6ddc42d65a8e23f9b1c409d51b8b895b4c3b28e4 (resized).jpg
fbcc4b724d42181cb0bdb3e4c5c6923858c50086 (resized).jpgfbcc4b724d42181cb0bdb3e4c5c6923858c50086 (resized).jpg
After clearcoats and sanded......hard to see with my own eyes.....
Some pinholes has been touched up with Blossom White on brush......
EDIT: Maybe use some removable adhesives to hold down....better than pins???
This is on right side, not sanded yet....tomorrow
I just finished cleaning up the coin door.....Yippeee!
With new lock, new red start button and white bushing....... also, new white entrance plates and label inserts.
New coin door decal will be installed at the end....
(I put cardboard papers in between frame and door to stop rubbing each other before install...)
#28 6 years ago
Sides finished with 2PAC....going to front ends....
Cut out masking paper and cleaning 2 edges with naphtha.....No sanding on any edge of 2PAC....not yet.
Blue masking tape around...
Cover up the sides with masking papers......
The cabinet front end face up.....
Cut and remove the masking paper....
Cover up the coin door area and edges....cleaning 2 edges with naphtha (blue lines)
Blue tape around and cover up the sides with masking papers......
First coat done.
After dry, paint clear inside coin door holes with brush, to prevent the wood from swelling up around the hole when wet sanding.... (I found 2 swelled next to holes on Super Spin project)
#29 6 years ago
Second coat......
After wet sanded, I don't see any unmarked spot....so I don't need a third coat...I'm done with 2PAC.
Remove all masking papers and tapes....everything!
Ahhh nice plywood bottom....I haven't seen it for a month!
Sanding very carefully on corners where 2 clearcoated sides together.......to make round and smooth corners...with 600 grit.....Do not sand the rest of edges....no, not yet.
Ahhh....a serial number....indeed
Saved the original stamped numbers....
Filled the nail holes.....
Removed the temporary legs.....
I made a post stand for backbox, to spray all sides and a bit insides at same time.....
For Cabinet, just spray inside side rails for now.....
#30 6 years ago
This is all just astounding. Thanks for your thorough documentation.
#31 6 years ago
There are lots of different kinds of clearcoats to choose from....I really don't know which is the best....
I choose this water based polyurethane....in a HVLP spray gun...
I have tried on Royal Flush, I liked it very much, it's very smooth and totally flawless, no orange peel finishes....and I didn't do anything after 3rd and final spray job, no sanding or polishing...nothing!
Colors looks good.
I add a little bit of water to make it thinner....to avoid an orange peel finish...but be careful.....easy to bleed!!
Polyurethane is very thin, at least 3 coats to complete.
It dries very fast, best to spray is on cool day (very early morning in So Cal), make sure the whole coat stays wet before finished spraying job.....otherwise, you'll see different sheens.
To knock down the artwork edges with polyurethane is probably 6-8 coats which is too much, that's why I choose 2PAC.
Testing on a kitchen sample door.....
First coat of polyurethane......
Close up detail of first coat....
Inside rails.....see the fine orange peel finish? it's from the rust-oleum painter's touch ultra cover spray can - blossom white... not from clearcoat.
On non-2PAC surfaces, I'll sand lightly between coats to eliminating orange peel finishes.
Ahhhh look at that 2PAC side...no orange peel finish!! ....and of course, no stencil edges!
It's a semi gloss finish.
After dry, it's time to sand (dry) to deburr the edges of 2PAC....very carefully...hard to see, just feel it with fingers.....don't sand too much, will sand again on second coat.
(see blue lines)
#32 6 years ago
Great work. I like your explanations ans step by step approach and tutorial.
Yves
#33 6 years ago
7:30am, 63F, 5 mph wind, overcast (June Gloom).....
Perfect morning for last coat on backbox...lots of pressure, high heart rate.....
I wanted the last coat to be perfect.... make sure enough paint and no rundowns because I really don't want to do another coat (whole thing) if screw up....I must wear optical glasses for last coat.
3rd and final coat.....
All good......whew!!!
Few hours later, new nylon cabinet glides installed.....
Backbox is done!!! No sanding or polishing after that...nothing.
The sun's going down, I took the backbox outside for better pictures.....all good, I'm happy.
Inside rails finished, now the cabinet is upside down on sawhorses.....
I'll spray a bit under, on the edge...
Cover up the coin door....
Can't spray now....too hot....will do in the morning.....
#34 6 years ago
First coat on main cabinet.....
After dry, sand to deburr the edges of 2PAC.... (blue lines)
Will do again on second coat if necessary.....
#35 6 years ago
The cabinet is a work of art, a mona lisa showing much love and attention to detail.
I look forward to see what you do with the electro mechanical parts.
#36 6 years ago
Don't know if the splatter pattern is typical of this title, however you have done one heck of a job with this cabinet. The title deserves this type of detail only because of the rarity, and you have done well. Good luck with the workings of the game next.
#37 6 years ago
Thanks guys....
3rd and final coat on cabinet.....all perfect!!....Cabinet paint job is done, done, DONE!! Yay!!
I made leg protectors out of a 4ft long vinyl base....$2.38 plus tax at Lowe's....enough for 8 pieces.....
Almost 1/8" thick, will prevent the legs from digging into cab....
A sheet metal template.....to cut the vinyl with Stanley utility knife....
Drill small holes as a guide....
Then a 1/2" speedbor.....
Put them on BBQ ...yum yum yummy...Ha! just kidding, to make them soften......
Fold in half and clamp them with 2 wood blocks.....ouch, a bit too hot with bare hands....sigh
Cool down under tap water .....
Bevel on holes with x acto
Also, beveled edges with a tiny trimming plane.....
#38 6 years ago
When you remove the legs and vinyl protectors from cab....of course, you will see some blemish finishes on cabinet.......with minimal damage.
Legs installed......
Tune up the chimes with a rebuild kit from PBR...
#39 6 years ago
I like to use these metal cabinet protectors from Pinball life: http://www.pinballlife.com/index.php?p=product&id=2711
but you did a great job with the plastic one. After spending so much time repairing the cabinet, it is essential to protect it in the best possible way.
Yves
#40 6 years ago
I did, bought the protectors and the new system 11 legs together for my very first machine, the F-14....not thick enough..... the cabinet got damaged by the sharp edges of new legs...
Bought another set of legs for my Williams Fire! but no more metal protectors for me.
#41 6 years ago
Hot, hot, hot, bloody hot!
Too hot to work in garage after 10am....so I took playfield to a cool dining room and do hand paintings...
Power went out for almost 12 hours last Saturday night.....then, I went outside....
Yikes!! I took this picture with my iPhone.....what happened? a plane crash??
Here's the link......
Ok, top playfield area done by hand paintings.......Yellow, purple and black only...all Createx paints.
Inside blue line....
Middle playfield area......done with yellow, black, red, purple and a bit of white on bird's eye....
Inside blue line......(notice: I repaired 2 damaged spots from hole kicks)
#42 6 years ago
Did you thin the Createx paint before brushing?
#43 6 years ago
Quoted from Silverstreak02:
Nope, nothing. A drop of createx into ice cube tray and paint it with a good brush.
A drop lasts about 5 minutes before it gets too thick....so, another drop of fresh paint on next spot......
Done with yellow and black.....original red is fine......
Hand painted on purple, black and white on "500" and "Special"
New lime green color.....
Yellow, purple, green, red and black......all hand painted
"Boomerang" shape is next.....with an airbrush and masking tapes....
#44 6 years ago
Lookin' great! Do you have "before" pix?
#45 6 years ago
No....sorry, how about this one?
Masking tapes and papers, to spray yellow.....
Yellow is done.
Next is green, I put masking tapes on every 2nd green triangle.....same thing what I did to yellow......
Repeat for the rest of triangles....
Boomerang is finished......purple is next
Before I put a masking tape, I paint the black line a little bit by hand....
Circle Cutter is very handy!!
A measurement for circle cutter....
Ready to spray it purple....
Blue tapes over the "Copyright" logo....do not spray over the blue tapes....just stay away from edges....
Purple is done...
#46 6 years ago
how about this one?
Uhm...yah. That'll do.
I like your work-around with masking off every other shape (to give yourself room for the tape/mask). Your registration continues to inspire. I can't spot even a hairline of a shape that's not in place. Flawless work.
P.S. Did you paint your bottom insert purple?
#47 6 years ago
LOL.
I use a magnifying lamp to keep my works flawless!
$35 from Harbor Freight...
Paint over purple insert? No way!
New insert. (see post # 16)
Doing the Egyptian crosses....hand painted white around "500"
Then masking tapes around for airbrush....
Crosses on lanes done.
I repaint the green triangles again....more lighter green.....
and sides on mid playfield at same time....
Inside blue lines...done today.
For whole lime green color on playfield....hand paint (see blue areas) and then airbrush the rest.
#48 6 years ago
The playfield is getting greener!!
I'm done with handpainted green........will finish the rest of green by airbrush later.
Going to hand paint white (blue lines)
Handpainted white is done, airbrush later.
Purple color is done! 100% !!
#49 6 years ago
To paint it green with an airbrush, top half for now......
See the hand painted green? Do not airbrush over blue tapes..(red lines)... otherwise, you can see raised paint edges from masking tapes...
Top half green done.....masking tapes for Egyptian crosses...hand painted white on bottom.....
More masking tapes for pop bumper rings.....
Masking tapes for bottom half green......
Green color is done....100%
Also Egyptian crosses and pop bumper rings......
Almost finished....just need to paint the white areas under playfield plastic set......
Masking tapes top half....and bottom half later......
ALL DONE!!!! YIPPEEE!!!
Green -100%
Purple - 100%
White - 100%
Yellow - about 60%
Red - about 25%
Black - about 10%
Brown for wood - 0.005%
Clearcoat is next.....I'm using this product....
Wiped off lightly with naphtha.....and a tack cloth......
First coat of 2PAC.........Flawless!!
#50 6 years ago
I like it. Goodbye dingy yellowed whites. That fresh coat of white paint looks great.
Lighting
Space Coast Pinball
$ 4.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/electro-mechanical-cleopatra-restoration-project and we tried optimising it for printing. Some page elements may have been deliberately hidden.
