Ok, I guess I am more of a mechanic and not an electrician. I bought this MSF and everything seems to work, but I noticed that the flashers do not work. Pulling the back glass I see that the F6 fuse is not int eh holder. So I pop one in and power up and it blow right away. I checked the plugs and tried again, same result. I pulled the PBB board out to check the transistors and they all test out OK as does the bridge. It looks like a couple of the sockets have been replaced. The relay looks to have been replaced also.
Trying the read the schematics that I found online are kind of difficult. Any suggestions as to where to start to look.
