(Topic ID: 246883)
Electrical flipper issue?
By MrFancy
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Billc479
#1 4 years ago
The left flipper went dead on my Firepower. I took it apart and put it back together and bent the EOS switch a little, and got it to "sort of" work. It flips at about 3/4 strength, and when you hold the flipper button down it wobbles back and forth a little at the top of the flip. I noticed that if you then press the right flipper button at the same time, the wobbling gets much faster, which is what makes me think it's an electrical issue. Also, the machine has always had issues with things like needing to warm up (sometimes for 1/2 hour) before it will play a game, having to turn it on and off several times to get the displays to appear, and sometimes starting the first game without all the sounds. I tested the batteries and they're fine, although they are lithium batteries and the voltage is lower than what you'd get with regular batteries. The flippers have been rebuilt fairly recently and the right flipper has no problems.
One other thing that may or may be relevant- in order to get the left flipper to work at all, I have to leave the bolts a little loose so that there's some play. If I tighten them up, the mechanism pushes the metal rod into the coil at a little bit of an angle rather than straight in, and it doesn't work.
Any ideas about the flipper? Could it be related to the other electrical issues?
#2 4 years ago
Quoted from MrFancy:
Did you replace the EOS switches when you did the rebuild? The proper gap should be 1/8" inch.
#3 4 years ago
Make sure the flipper pawl is tightened in the correct spot on the flipper shaft vertically. If it’s too high or too low the plunger will bind in the coil sleeve when the solenoid pulls in.
#4 4 years ago
Thanks guys. I left it on all day today, which I hadn't done before, and the flipper works almost perfectly now. So, it seems like this was probably related to the other problems I was having, and the underlying issue is just that the machine just needs a really long time to warm up before it functions properly? Not the end of the world, but anything I can do to remedy that?
#5 4 years ago
Should be on and ready in just a few seconds. I would take a close look at voltages on the power board after you turn it on and see what you have. That will point you in the right direction.
#6 4 years ago
Maybe a capacitance issue then, all original caps on the boards?
#7 4 years ago
Without checking voltages, it’s hard to say, but that would be a good guess
$ 170.00
Displays
Digipinball Shop
2,900 (OBO)
Hawesville, KY
Trade
Machine - For Trade
Washington Court House, OH
Tools
Pincoder Store
$ 42.95
$ 11.00
Playfield - Plastics
The Pinball Scientist
1,400 (Firm)
Benton, PA
$ 27.95
$ 12.00
Tools
Nezzy's Pinball Prints
600 (OBO)
Casper, WY
This page was printed from https://pinside.com/pinball/forum/topic/electrical-flipper-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
