Game is a 1948 Bally Carnival.
In need of replacing the Graphite or Carbon electrical contact rings for the bumper hit registers on the underside of teh play field board.
These are small rings that are about 3/8" OD x 3/16" ID and 1/4" thick with a small groove cut in the outside circumference for a 1/16" diameter copper wire to hold them in position.
When the bumper is hit, the hanging rod will swing sideways and hit the ring. The rod and the wire that holds the ring are both wired to be a contact switch when they meet. As they contact, the circuit is closed and the relay will kick in to register a score.
These rings are designed so as not to have common metals contact each other and cause them to weld together.
In time the carbon/graphite rings wear thru and fall out.
I need about 20 of these now to bring the machine back to proper safe working condition. I have not seen any of these for sale.
WHERE CAN I FIND THESE?
