(Topic ID: 216064)
Eldorado drop targets stick. First one down.
By SteamVette
2 years ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by SteamVette
#1 2 years ago
So I purchased a Gottlieb Eldorado EM game. Everything has been gone through with new targets ect. So when i start a new game and hit any of the drop targets for the first time on the top bank of targets it takes a while for the first one to go down. Then all the others drop as they should. Doesn't seam to matter which target I hit first its always slow. Any tricks to this? Everything seams to be in order? Tried to upload a vid but I can only do a photo.
Photo below is not my machine. Mine has new targets. Reference only.
#2 2 years ago
Check for the binding in the reset bar and solenoids under the playfield. Sounds like the mechanism is sticking.
#3 2 years ago
I can see when the solenoids reset the targets they stay in the pulled position and that first target has a hard time pushing them back out. Should the solenoids automaticity push back out? See pic. Easy way to adjust them?
#4 2 years ago
They should only retract, that is the plunger should move into the coil, when resetting the targets. Then they should extend into the non-reset position by themselves. There usually is a return spring. These are 120 volt coils, so unplug the machine to work near these. They need to work smoothly. I have seen them get sticky from dirty coil sleeves.
#5 2 years ago
Thanks, I don't see a spring connected to the restet bar. i would think a spring would help place that back into the non reset posistion. I will clean the sleeves to see if that helps. If any one knows of a spring on this bar please let me know.
#6 2 years ago
There should be two torsion springs, one on each end of the reset bar.
#7 2 years ago
Mr Leckmeck beat me to it.
The axle for the reset bar has the spring on the ends. The smaller target banks that only use 1 reset solenoid "might" only have the torsion spring on one end. Pictured below is one of the springs from an Atlantis 10-target bank. The Gottlieb part number for the spring appears to be A-13455. If your target banks have the spring(s) intact, then the pivot points (and solenoid coil sleeves?) might be gunked up and sticking.
#8 2 years ago
Suggest you get a copy of the 1978 Volume P Gottlieb Parts Catalog from Pinball Resource if you plan to own 70's wedgeheads. It is a must have resource. All of $20.
http://pbresource.com/books.html
#10 2 years ago
Quoted from MikeO:
Agreed. The exploded-view diagram of the drop target bank assembly is amazing.
Original copies sometimes turn up on eBay. The reproduction doesn’t have the spot colors.
#11 2 years ago
Thanks all. I purchased a copy of the parts catalog book...
$ 4.49
$ 200.00
Professor Pinball
Metal-Mods
Filament Printing
Displays
GermanGamingSupplies.com
$ 70.00
Cobra Amusements
€ 159.00
FlipperLED
$ 86.95
$ 16.00
Pin Monk
$ 8.00
Cabinet Parts
Buthamburg
$ 6,299.00
Classic Game Rooms
$ 249.99
Id Rather Play Pinball
$ 149.00
$ 119.95
Hookedonpinball.com
$ 24.95
Hookedonpinball.com
$ 279.95
Pin Stadium Pinball LEDs
$ 5,899.00
Classic Game Rooms
$ 229.99
