Hi All,
I'm pretty new to this forum and I am hoping yop can help with a problem.
I was playing my Lazer Ball when the power in my home suddenly went out and then back on, all in about a half a second.
Since that happened the solenoid for the Eject Hole (next to the drop down targets on the upper left) stays activated. By the time I realized this and found the key to access the playfield, the solenoid started smoking.
I replaced the burned out solenoid and a couple of transistors on the driver board that were bad, and checked all the fuses, but that didn't fix the problem. Any suggestions on where I should look? I don't want to go down the wrong road, so any input is welcomed.
Thanks in advance,
Scott
