I am looking to purchase a EBD tomorrow but the guy says the transformer is shot. I have been looking all day and can not find one. Do they exist?
Quoted from Skyemont:I am looking to purchase a EBD tomorrow but the guy says the transformer is shot. I have been looking all day and can not find one. Do they exist?
New ones? No.
Transformers do pop up on ebay occasionally.
You'll need an E-122-142 transformer.
http://pinwiki.com/wiki/index.php?title=Bally/Stern#Bally
But, you might get lucky if the problem is on the rectifier board, rather than with the actual transformer.
Quoted from Skyemont:So Speakeasy uses the same transformer?
A number of titles did, including that one. The part numbers for the games and transformers are listed on pinwiki.
I doubt that the transformer is bad. Very-very seldom is this the issue..
Read the pin-wiki, or find Clay's old guide on -35 pins. More likely a problem with the rectifier board.
In reference to Bally AS-2518-54 Rectifier Board A2 Assembly (EBD board version 2):
I have only seen three? transformers have problems in nearly 30 years.
One was caused by crystallized solder joints, so not directly the transformer after all connections were reflowed.
Another was inside the windings due to an electrical strike through a cabinet MOV, so the transformer was toast.
The third was short circuited by owner hacking connectors, so the transformer was toast.
Common problems:
High Current Fuse Clips
Bridge Rectifiers w/ Wires (200V 35A)
IN4007 diodes
100 Volt MOV
Careful when voltage testing, the current can kill. Keep a family member nearby with a wooden stick
Once you verify the test points, rebuild the board, unless it is a hot mess.
If you are really in pickle, and the transformer truly is bad, remember video arcade games from the 80s used the same transformers in many cases.
Quoted from ForceFlow:New ones? No.
Quoted from dasvis:I doubt that the transformer is bad. Very-very seldom is this the issue..
Quoted from xTheBlackKnightx:In reference to Bally AS-2518-54 Rectifier Board A2 Assembly (EBD board version 2):
Common problems:
IN4007 diodes
100 Volt MOV
Quoted from Pbpins:Yes, they do exist, I have a few good transformers!
Thanks everyone. I am getting it on Tuesday. I may be looking for a transformer if it is the problem. If not, thats good too..
Quoted from greatwichjohn:I have seen a few transformers go bad.
Well i am getting the pin saturday. I will look into this and see if it is indeed a transformer. If so, i will pull it out of the speakeasy i am getting. Win win..
They almost always need the rectifier board either repaired or replaced. The new aftermarket boards are nice. Very rarely are the transformers bad.
There are other machines from the era that used the same transformer and rectifier board.
The hardest Bally SS pin to find a transformer though is Kiss. Only two other pins use the same transformer (Future Spa & Space Invaders) and they can be very hard to find and expensive when you do find one.
If you still need another:
ebay.com link: BALLY EIGHT BALL DELUXE PINBALL MACHINE CABINET TRANSFORMER ASSY
Looks to be in good condition, rectifier board missing.
Possibly related question for an Eight Ball Deluxe: I have a hum on my machine. It comes from either the transformer or the rectifier board (my power knowledge is sketchy at best). It varies slightly in loudness during 'attract' mode as the lights are flashing (so maybe on draw from the bulbs). Is there a short somewhere that's causing it? Just age?
If I wanted to get rid of that hum, would that likely be the transformer or the rectifier board? Or, is this a common symptom of some other underlying issue?
Wish I could describe better. Greatly appreciate any sage advice!
Cheers.
Quoted from mirthful1:Possibly related question for an Eight Ball Deluxe: I have a hum on my machine. It comes from either the transformer or the rectifier board (my power knowledge is sketchy at best). It varies slightly in loudness during 'attract' mode as the lights are flashing (so maybe on draw from the bulbs). Is there a short somewhere that's causing it? Just age?
Cheers.
More than likely, hum issues are going to point to problems with the sound board, bad speaker, poor connection, a broke off ground pin on your power cord, or a bad potentiometer in the cabinet. Not always, but those are more likely than a transformer issue.
Quoted from snyper2099:More than likely, hum issues are going to point to problems with the sound board, bad speaker, poor connection, a broke off ground pin on your power cord, or a bad potentiometer in the cabinet. Not always, but those are more likely than a transformer issue.
Great point on the power cord -- my ground pin is broken. I'm replacing that ASAP. Also like your other suggestions. thx for the feedback!
K's arcade has refurbished transformer with rectifier board.
Also the same as 6 million dollar man, kiss
This page was printed from https://pinside.com/pinball/forum/topic/eight-ball-deluxe-transformer-do-they-exist and we tried optimising it for printing. Some page elements may have been deliberately hidden.
