(Topic ID: 274327)
Eight Ball Deluxe rollover issue
By phillyfan64
1 year ago
  • 18 posts
  • 9 Pinsiders participating
  • Latest reply 1 year ago by pindel
#1 1 year ago
Is there anything in the switch matrix that could cause the game to occasionally not register a rollover? I've had this issue before. I thought I had it resolved. Sometimes it's the left outlane. Sometimes it's the top left rollover switch. Every once in a blue moon it's the right outlane. I've replaced and regapped the outlane switches. Replaced the caps, replaced the diodes. Alltek MPU. Repinned J2. But every once in a while I still see this issue. Is there a diode or something somewhere else I should be looking at?
Yesterday during a game I hit the top left rollover and it didn't register. Then a few seconds later I hit it again and it seemed to jump 2 bonus positions, like it was catching up to the earlier miss. I don't know if that's a clue or not but I've never seen it do that before.
#2 1 year ago
Anyone? Bueller?
#3 1 year ago
That's a tough one, you've basically gone over all the things i would have suggested. Only thing i can think to do at this point would be to double check your crimps at J2, and check every switch's diode, cap, and wiring very closely for any potential short-circuits to nearby wiring/metal/etc. Problems like this are usually the most difficult to track down because it's happening intermittently.
#4 1 year ago
Thanks. Yeah it’s a tough one. I can’t duplicate it. It just happens every once in a while. I know sometimes the game will score correctly even without a sound effect which from what I’ve read is quite normal for this game. This can happen if the game is “talking”. But there’s definitely some instances where it’s not registering.
#5 1 year ago
Quoted from phillyfan64:
Can we presume it's happening when the ball is traveling at high speed?
What's the chance that the ball might be slightly airborn over the star rollover so the switch isn't making contact when it happens?
Have you verified the switches make contact when the ball goes through along the hard left and hard right edges of those lanes?
#6 1 year ago
Quoted from Quench:
Yes it’s usually at a high rate of speed. I suppose it’s possible that it could be slightly airborne over the star rollover. It’s hard to tell. The left and right outlanes are gapped really close, probably 1/32” of an inch. It appears to be making solid contact. I have .047 uf caps on there. These caps are really tiny physically. Not sure of the brand. Maybe I need to try a different brand of capacitor. These are from Great Plains Electronics. I have some pretty large size ones from PBR that are the same value. Might be worth a try to swap them.
#7 1 year ago
You wouldn't normally need switch caps on outlanes. Star rollover, yes, but not regular lane switches.
#8 1 year ago
Are your switch contacts nice and clean?
BTW, have you got capacitors on the flipper return lane switches? My EBD would miss switch activation on those lanes sometimes when the ball rolled through them too quickly. The game went into storage before I could put caps on those switches.
#9 1 year ago
Quoted from Quench:
Switches are clean but I will go over them again with a business card. They are new switches. Well maybe a year or so old. I do also have new switches and new caps on the flipper lanes.
#10 1 year ago
Has J2 on the MPU been re-pinned? Has the header been reflowed.
Maybe it’s a continuity problem.
Just throwing it out there, as you’ve covered everything else.
#11 1 year ago
Quoted from Validpowerdetect:
J2 has been repinned. I did that one myself. I thought that resolved it last year but it has come back. The MPU is an Alltek board that’s probably 2 years old. I haven’t looked at the header but I might as well at this point.
#12 1 year ago
A lot of times on my EBD, with the outlanes in particular, seems the game won't make any scoring noise when it goes thru but I sort of think it's because the game is making some other sound effect at the time, and it probably did register even though I wasn't watching to see if it actually scored. Can't remember being ripped off when they were lit for special though. Did you try them in test or manually in play mode repeatedly and still get some misses?
#13 1 year ago
I know what you mean about it going through the lane silently because the game is busy making another sound effect. I’ve seen that several times and it does score. But this is different. This is occasionally not registering. I’m sure of it. I have not been able to trigger any missed scoring manually.
#14 1 year ago
I'm currently work on this issue as well. Just got my game back after a playfield swap and everything looks in place.
Goofing around with gap and have cleaned all contacts
I do notice on a soft shot where the ball doesn't go all the way up and starts to fall back
it registered twice, which tells me it is perfect at that rate of speed. Keeping that in mind, all fast shots
fail to register at all.
I feel like it's more of the rollover not actuated the switch then the switch or contacts
Is there a way to make the Botton of the rollover longer to hit the switch more accurately???
#15 1 year ago
Quoted from DigitalJB:
The star rollover definitely needs a capacitor on the switch. Do you have one on there? Is it new or old? If it’s old, replace it. Even with that, there are a few times when it may not register but it will help. If that ball flies through there and is maybe off to the side, it may not register. Make sure the switch contacts are really close and clean. There was a post a couple years back where somebody modified the plastic star a little that seems to help. Let me see if I can find it.
Edit, found it. Go to page 31. Post 1535.
https://pinside.com/pinball/forum/topic/eight-ball-deluxe-owner-club-guests-welcome-as-well/page/31#post-4113625
#16 1 year ago
Pretty sure there was a cap but I will take another look
Good info - Thanks!
#17 1 year ago
I had a similar issue with a star rollover on my Black Pyramid. Found a little bit of playfield wax had gotten down into a couple of the star splines and had dried causing the star not to depress fully to activate the switch.
#18 1 year ago
Getting the star plastic piece to glide easy is super hard on a new playfield. The clear has everything clogged up. You have to clean/remove the clear in the groves. Also the new star has a lip on the post that needs to be smoothed.
