(Topic ID: 285782)
Eight Ball Deluxe insert question
By bk2futr
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by bk2futr
    #1 3 years ago
    Hi. I have a EBDLE i just picked up. It has a real nice playfield someone put in. My issue with it is when they put the inserts in for the drain on right side they mixed up the red and green.
    So my D is red and Special is green.
    Is there an easy way to fix?
    I cant find just the D decal and hate to have to buy a whole set.
    I see the inserts are available and cheap.
    I just dont know exactly what kind to get just yet.
    Will they get messed up removing them?
    Will I mess up the playfield removing them?
    Any advice would be appreciated.
    #2 3 years ago
    You would need to heat up insert and tap it out. Then sand off the D and swap the two. Glue in and add new decal. Sounds like a lot of work with risk of playfield splitting around inserts. I would leave it or do a playfield swap with new playfield. A new playfield would add thousands of dollars in resale value.
    #3 3 years ago
    I think that you’re stuck with it as it is.
    I suspect that it is a playfield overlay and you would have to scrap it entirely if you go the route of swapping the two inserts as described by pindel.
    #4 3 years ago
    It's not an overlay. At least I don't think it is.
    It's a new playfield..
    Do new playfields come with the inserts in them?
    I don't know if it Is a new old stock or reproduction..
    Would it still split you think?
    #5 3 years ago
    Quoted from bk2futr:
    For me I would say doubtfull...just a little bit of work.
    #6 3 years ago
    Only you would notice that - it’s not going to be easy to fix. But it is doable...
    #7 3 years ago
    Thanks all for the suggestions. I am leaving it for now. At least until I get everything else done the way I want it.
    Then I'll see how bad it bugs me
    Thanks again!
    This page was printed from https://pinside.com/pinball/forum/topic/eight-ball-deluxe-insert-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
