Quoted from BigAl56:Bally games marked where you could shift the posts slightly on the outlane to make the game easier or harder. What you are seeing is a pre punched marker if you wanted to move the posts in essence making the drain opening larger or smaller.
Thanks, but no... as I mentioned in my original email "...schematics show the rubber goes around three posts." I'm talking about the rubber behind the upper flipper, not the posts near the outlane.
I've attached a pic from the manual. I'm talking about the dotted line above the arrow, to the right of the flipper. This indicates there are three posts. And the rubber I have remaining fits three posts, and not two.
But you can see in the second pic that joelreeves recently posted, there are two posts and behind the flipper you can see where the third post should be.
In the other image I attached you can see the rubber and the post. But it looks like things changed at some point, and they stopped using that third post.
So now my question is, what size is the rubber that goes around two posts? The one I have now is 1" so do I need a 1/2 inch?
For the flipper coil, my issue is the right flipper has two switches. One open and one closed. My solenoid has 3 wires coming out of it, with 4 posts to attach. The question is, how do I wire it up? I can't find it on the schematics, and joelreeves posted some great photos, the first one of the flippers is the flipper I'm talking about. EXCEPT there are a bunch of wires in the way. So I can't really see how it is wired up.
Joel thank you so much for the photos. Is it possible to get another photo of the bottom right flipper? I need to see how the switches are wired up. The photo you posted has a bunch of other wires in the way.
My problem is... I've got two games. One is missing in the right flipper completely, while the one I'm working on, someone scrounged the switch
