In January 2022 I focused on building a new playfield with some geometry changes including a wider spinner shot and a three bank of standups in front of the pop nest. I had used up the plywood I originally purchased for my first layout back in 2019 so I made another trip to Crosscut Hardwoods in Seattle and had another 4x8' sheet quartered. The price of baltic birch had certainly increased since my last visit...
I wanted to cut the playfield myself this time so I took a course in CNC operation from The Facility Makerspace in Edmonds, WA. If you're in the area I highly recommend them because the staff is super helpful and the space is very well equipped. I was operating the machine in no time after taking the course.
Before jumping into the playfield, I started with a piece to test insert fit and the shooter lane cut. I also cut an incorrectly sized speaker mount for the cabinet. Oops!
First time using a CNC
Life got in the way after this so I didn't end up cutting the playfield until the following August. I found myself becoming comfortable with putting the project away for several months like this. Sometimes the motivation just isn't there.
First playfield cut
I used a 1-1/4" core box bit for the shooter lane, a 1/4" upcut bit for large cutouts, and a 1/8" upcut bit for inserts, through holes, and switch slots. Overall I was happy with how it turned out but the insert cuts caused some minor chipping on the surrounding surface. Next time I'd like to experiment with a downcut bit and/or different speed settings to minimize this.
After installing the inserts, I realized that this would be the playfield that I would take to the Northwest show so it needed some artwork. The artist I had been working with hadn't yet started on the playfield but I still wanted to have some basic graphics so players knew what they were shooting. Before clear coating, I took a few weeks to put together some one color graphics in Inkscape with the help of some icons I downloaded from thenounproject.com. I used my vinyl cutter to make several black vinyl decals that I applied using transfer tape.
Inserts installed
Vinyl decals
Vinyl application
Vinyl decals close up
Playfield before clear coating
I was super happy with how crisp and clean the vinyl looked with the bare plywood. I think it could be a really neat effect if a one color playfield was made this way with proper artwork.
Next up - clearcoating!
