Quoted from Deez:subscribed - I'm curious how this programmer works. I wouldn't mind having a backup.
It's a handy programmer; I have the TL866A which has the extra feature of In Circuit Serial Programming for Microcontrollers and SPI EEPROMS over the cheaper TL866CS but I haven't used the feature yet.
But as mentioned above the lack of 25V programming support is an issue in this arena unless you're stocked up on 21V or lower parts.
There is plenty of discussion on this programmer here if you're interested:
www.eevblog.com/forum/blog/eevblog-411-minipro-tl866-universal-programmer-review/
Umm, this is probably the hard way but if you're using a Windows PC, you can do it in a Command Prompt (assuming you're familiar with it). The command is something along the lines of:
copy 2716file.rom /b + 2716file.rom /b 2732file.rom
Replace "2716file.rom" with the name of the 2716 file you need to double.
"2732file.rom" will become your new 2732 rom file.
Actually, you can also do it in the MiniPro programming software. Select a 2732 device. Load your 2716 file with the "From file start address" set to 00000 and the "To buffer start address" set to 00000 and click OK. When it's done, open the file again but this time change the "To Buffer start address" to 00800 and click OK. Then program your 2732 and/or save the file as a new 2732 version.
Hope this helps.
