understandable... here is what i would do if i was you....
important edit: take pictures from every angle every step of the way...
- remove the pf from the game...
- unscrew the switches from the frame... i just wrapped a piece of painters tape around them to keep them together, or you can use nuts, or if you are like dirtflipper and can put together an entire pinball machine blindfolded, just toss them aside...
- release the coil from the frame...
- unscrew the bank from the game, and lift off....
- follow these instructions on how to disassemble and reassemble... replace any triggers that even look like they are worn, they are cheap, and you don't want to do this twice to save a buck... i'd also replace the springs, others will feel differently about this...
http://www.pinwiki.com/wiki/index.php?title=EM_Repair#Drop_Targets
do the complete disassembly and clean everything...
- i (and others) apply a tiny amount of superlube to the trigger switch to allow it to glide easier... others feel differently...
- put it back in the machine, re-attach everything, test... adjust switches if needed...
