(Topic ID: 299923)
EBD restoration/repair.
By DreB
49 days ago
  • 7 posts
  • 6 Pinsiders participating
  • Latest reply 43 days ago by Forehead_Slap
#1 49 days ago
Hi everyone, restoring/ trying to get everything up and running on my recently purchased EBD. I had some burnt resistors on my solenoid board as well as some of my MPU. A fellow pinsider name Quench helped me out alot with those issues and now I still have no displays nor sound. I just noticed my sound board is upside down, is it plugged to the wrong connectors like this? Tks
#2 49 days ago
Board is mounted upside down like that on IPDB, looks normal.
#3 49 days ago
Quoted from frenchmarky:
Ah. K good to know.
#4 49 days ago
I'd be removing the ni-cad battery on your MPU board asap and replacing it with a supercap, battery pack or nvram.
Bally must have changed the positioning of boards at some point
#5 49 days ago
RE: displays, what DC voltage do you measure at test points TP4 and TP2 on the solenoid drive board?
Note1: these are typically high voltages in the range of 180 - 240 volts so take care measuring.
Note2: you'll need to set your multi-meter to the 600V DC scale.
#6 46 days ago
Looks like you have the later run EBD. The S&T board is sideways and not upside down. Probably because the later cabinets were narrower.
So the game boots? Your getting 7 flashes on the MPU? Check the key position on the S&T and the aux lamp boards to be sure your not getting those cables reversed.
Measure voltages. No coils is 43v issue. Check 5v jumper on J3 of SD board.
No displays could be bad fuse on SD board.
#7 43 days ago
In addition to this, the fuse on the SDB is supposed to protect the display, so check to see if it's blown.
Quoted from Quench:
