(Topic ID: 233278)
EBD everything working wont start a game
By zello
2 years ago
  • 17 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by FatPanda
    #1 2 years ago
    I have an EBD That was working years ago but now wont start a game.
    The MPU boots the attract fully work lights and sound. All the Selonids fire. The ball through switch seems to work. The coin door start but seems to work. It makes the sound. no fuses are blown.
    any ideas?
    I have an altek mpu i will dig out and try.
    #2 2 years ago
    Is it in free play? Did you put quorters in?
    #3 2 years ago
    Freeplay. Everything seems to work just wont start a game.
    #4 2 years ago
    Switch in outhole working so the game knows a ball is there ?
    #5 2 years ago
    It is physicaly working and making contact... been so long i forgot how to switch test on the machine
    #6 2 years ago
    Put the machine in self-test mode, get to the switch test, and make sure the coin door credit button is being recognized during the test. The credit button is switch 06.
    #7 2 years ago
    switch test.... when the ball is in the out hole switch 8 registers till i remove the ball. the coin door button switch 9 registers when held as well.
    #8 2 years ago
    I had a shorted tilt causing the same symptom when I first got my Paragon.
    #9 2 years ago
    wouldn't that show in the switch test ?
    #10 2 years ago
    Quoted from zello:
    If you are in switch test mode and you press the credit button and a "9" is displayed, you have a problem because the credit button should register a "06". "9" is for one of the coin switches on the inside of the coin door.
    #11 2 years ago
    So the start button makes a sound but the game doesn’t leave attract mode? Or the start button sounds and a game starts but ball is not sent out into the shooter lane?
    #12 2 years ago
    #13 2 years ago
    Check ball roll tilt mech
    #14 2 years ago
    If there is a capacitor on a tilt switch, I would clip one leg to check if it has shorted out.
    #15 2 years ago
    I reseated all the connectors. its running now!
    #16 2 years ago
    Quoted from zello:
    Sounds like you have a little repinning job in your future
    #17 2 years ago
    Reflowing solder on the header pins does wonders
