Quoted from Kovac:I'm a little bit confused. How switches relate to those five solenoids not firing when ball hits them.
It can't be that suddenly all five leaf switches stopped working...
The switches are scanned by the mpu board. The software decides when to fire the solenoids. It's very possible that the entire column is out at the same time via a bad connection via a connector, board pins, or broken chained wire. BTW they are pop, jet, or thumper bumpers. Mushroom bumpers refer to a specific different type of bumper that's a lot smaller, as seem on the playfield of Fireball if you want to look at a pic of one on IPDB.
Go into solenoid test, make sure the pops and slings are firing there. Then go to the switch test with all the drops up and the ball out and press each of the switches. I doubt that any will activate, so time to start tracing where the wires are going.
You might want to consolidate your various issues into one post BTW sort of a one-stop-shop.
