Hello!
1) I picked up an EATPM this week that needs some love and as I've fixed a few things already, I can't seem to figure out why the top row and a half of backbox GI lights are not coming on.
When I got the game, I looked in the backbox and saw a typical burnt connector on the GI plug and the left-most pin connector was black and gone. I traced the wire to a 'mod' where someone stripped a section of the yellow wire going to the GI input connector and soldered the red wire there. I happened to have a correct replacement connector, so I rebuilt it and inserted the wires into the new connector and when I turned the game on, I had no backbox GI. Doing nothing else, a few min later, the previously working GI came back on, except for the top row and half of the next row down. So, I follow the wires that connect to that particular line of GI lamps and I trace it to the white wire with color bands and that is the 3rd or 4th wire inserted in my fresh connector. Shy of pulling that board and reflowing the header pins, is there anything else I should check? Seems like a straightforward circuit, but I'm waiting on my manual. Is there a fuse that handles just that portion of the backbox?
2) What is the relay board for that is screwed to the backside of the light panel? This particular board has seen better days - a previous owner had soldered a wire directly to a pin and another wire to the underside of the board. I reflowed the pins on that board and rebuilt a 2-pin connector for those two wires, but have not noticed anything working or not working since I made that fix. It does not appear to be connected to the row of GI lamps that is out, so I'm not sure what it's doing there.
3) I am noticing some Flashers are not working (both flashers under the boogie men nor the left/right outlanes). I suspect once I get the manual delivered, I can trace the switch/flasher matrix, but I haven't worked on this particular game before, mostly older Bally's. Where might I look to fixing flasher issues?
Thanks in advance for any guidance!
Ryan
