(Topic ID: 75980)
Easy way to lift pinball machine adjust back levelers without a pin dolly
By barakawins
5 years ago
  • 33 posts
  • 27 Pinsiders participating
  • Latest reply 5 years ago by Shoot_Again
    #1 5 years ago
    What is the easiest way to adjust the rear legs on a pinball machine for proper pitch if you don't have
    a pinball dolly at hand? Any tips?
    13
    #2 5 years ago
    Crawl under the game.......use your back to lift the game....adjust each side as needed.
    #3 5 years ago
    Yes that's what I do
    #4 5 years ago
    Quoted from mezzblue:
    Ditto
    #5 5 years ago
    Yeah same here. I fire up my level app on my iphone, putr on the playfield, crawl under the machine and lift with my back. I make some adjustments, crawl out, check the level, and repeat about a dozen f'n times.
    #6 5 years ago
    Ok cool about the back thing cause I thought I was the only one who did that. Better if there is a rug under there to cushion your knees.
    #7 5 years ago
    On all my EM games i use a 3/8" open end wrench on the nut at the lower part of the threaded stem
    and turn the leg leveler up or down and leveling the game.This is done without lifting the game with my back.
    #9 5 years ago
    Yep, works best... especially with other games next to it
    #10 5 years ago
    Bear crawl is it, that's why I bought a trolley best 300 bucks I ever spent
    #11 5 years ago
    There's gotta be an easier way to raise and lower without a pinball dolly and usage of back. Anyone else?
    #12 5 years ago
    I have the Teflon sliders under legs...games on carpet. I can turn the leg levelers up/down mostly by hand(sometimes have to use a wrench)w/out lifting. Got the Teflon sliders at Target...6mm concave I think they are. Leg leveler fits perfectly in them and makes moving and leveling a breeze....my 2cents anyway.
    #13 5 years ago
    Cash_Riprock is right, sliders are the way to go. I use Magic Sliders and I can adjust all the levelers by hand just by twisting the sliders, makes the whole process a million times easier and quicker. Also got them at Target.
    #14 5 years ago
    I have a lifter and due to the tight arrangement of games in the game room I use the bear crawl method also.
    I throw down cardboard or foam to save my knees the grief but always just do it the manual way.
    #15 5 years ago
    I use a Craftsman digital level. It beeps when it hits 0.0°. I use a small bottle jack with a 12" 2x4 standing longways on top of it. Jack slowly and when you hear the beep, screw the leveler into place.
    Jason
    #16 5 years ago
    Take a bar stool or something sturdy of that height, put it right next to rear or front of pin, lift up that end and rest it on your thighs as you slightly crouch and then quickly put the stool under it.
    #17 5 years ago
    You can use a crow bar under the leg to take the weight off of the leveller to adjust it.
    #18 5 years ago
    I use a saw horse and lift up the machine and slide the saw horse under it. That keeps either the front or rear legs up off the floor so you can adjust or replace the legs or leg levelers. When done raise machine and pull saw horse out. You still have to use your back but only once to put saw horse under and once to take it out.
    Al
    #19 5 years ago
    Ya man...
    Just use a wrench and adjust them the way they were designed to be adjusted. No need to lift anything....
    #20 5 years ago
    Quoted from Cash_Riprock:
    Cash, do the Teflon sliders want to curl up on the outer edges from the weight, or do they stay pretty flat? I was going to try some sliders on mine but I've seen some used for furniture that curl under prolonged weight.
    #21 5 years ago
    Quoted from barakawins:
    Take your level with you under the game, lift game with your back and raise the back legs to the max and level side to side off the bottom edge of the cab.
    Move out to the front and set pitch and side to side with the front levelers.
    I am tall so I set the games as high as I can.
    #22 5 years ago
    I agree I have sliders on mine and can usually do them by hand without even lifting but my back is right there if I need to.
    #23 5 years ago
    I get down on my knees and put a pillow between my upper thigh and the bottom of the machine and then flex my foot upward, thereby lifting the machine. Pretty easy. It might help that I'm on the taller side.
    #24 5 years ago
    I cant believe the bear lift maneuver is being suggested. Have any of you ever thrown out your back? I use a pinball dolly but it does not get the lift needed in the back to extend back legs all the way down so I add a piece of wood to back of dolly. Not a very elegant solution by any means.
    #25 5 years ago
    Why do you have to lift the game to turn the leveler?? I always adjusted levelers with just a thin 3/8 inch wrench on the squared part of the bolt. With one finger you can lift or lower the weight of the machine. You still have to crawl under the game.
    #26 5 years ago
    Quoted from marspinball:
    I know, right?
    Mechanical advantage is only an advantage when you.....TAKE ADVANTAGE OF IT!
    #27 5 years ago
    This is what I have always done
    #28 5 years ago
    You don't need to lift the game at all to adjust the leg levelers, as a few others have already pointed out. I just set my digital level on the playfield, crawl under the game with my two wrenches and make the adjustments, crawl back out and check the results. Wash, rinse, repeat...until the desired result is reached.
    #29 5 years ago
    Some leg levelers don't have a way to grab on to them. They're just threads. No hex nut to turn on them.
    #30 5 years ago
    tamoore that well work grand on a new game but do that on some of the old legs from the 70s and 80s.
    More than once I had to spray penetrating oil on the leveler bolts in order to turn them.
    no issues with 90s or newer usually.
    #31 5 years ago
    Quoted from Shoot_Again:
    I spend the few extra bucks and put new levelers on every game I get. I've never had a problem leveling a game.
    #32 5 years ago
    Quoted from RWH:
    That's why I got the ones from Home Depot, the plastic is nice and thick and the rubber inside is very firm and thick. They are also the right diameter, 5 inches. I've tried a few different ones and these are the best. 8 for 9 bucks I think.
    #33 5 years ago
    Quoted from SchertzPinball:
    Have to get them off to replace them. Anything in this condition I do replace.
    $ 45.00
    Just 3D Mods
    $ 40.00
    Metal-Mods
    Music City Pinball
    $ 209.99
    PinballBulbs
    German-Pinball-Modular
    $ 99.99
    Metal-Mods
    $ 29.95
    Medisinyl Mods
    PinWoofer
    CzTV Mods
    $ 13.00
    Yorktown Parts and Equip
    Gameroom Mods
    $ 189.00
    Displays
    Boston Pinball Company
    $ 76.95
    $ 154.00
    Id Rather Play Pinball
    $ 48.00
    $ 47.00
    The MOD Couple
    $ 9.95
    Apparel - Unisex
    Pinball Wheezer
    $ 19.99
    $ 5.00
    $ 229.00
    PinballBulbs
    Hardware
    CPR Playfields
