Thing I did to install art blades for FH 2.0 w/o help or removing pf. If you’re nervous about doing art blades, I say this is an easy and fast method due to that it uses Rapid Tac which makes the process forgiving (soapy water is probably similar though I’ve never tried it)
Use a rope to position pf like so
Lay decal face down on a surface and peel backing.
Spray cabinet where decal is going, and the decal sticky side, liberally with rapid Tac.
Lift and hold decal on opposite ends, slide it down between pf and cabinet into place (one arm on each side of the pf). While wet you move it, lift it, smooth it, etc
Use a cloth to squeegee out the decal, wipe up excess fluid
As rapid Tac dries, keep pressing on any parts of decal coming up. It will dry within minutes, restoring full adhesion of decal and it will stick down.
Before it dries move pf up/down to access and smooth out area that was covered by pf.
