Machine: Earthshaker System 11B
Issue: Under Ramp/J bumper flashers locking on (White/brown wire connected to PIN 9 on 1J12)
list of events:
*lots of corrosion from batteries that affected game operation
*cleaned up/neutralized corrosion and replaced SCR1-5, U41, R53, R54, R55, C30, 1J21, 1J22
Also removed very minor non battery related corrosion from U54 and U56
With that the game is fully operational except the aforementioned flashers locking on.
Steps taken to fix it:
Q6 was replaced and the board was tested in a separate machine.
*Issue persisted (which should rule out everything accept the CPU/Driver board )
Q6 was replaced again along with Q2, SR5 and U17
*issue persisted.
And with that ... that is were i am stuck.
